Need a little help
Old Jul 14, 2005
2k5EP's Avatar
2k5EP is an unknown quantity at this point
Need a little help
Tonight i was trying to install my headunit...using the DYI... I could not get the silver lining around my tranny out... By the way its an 2005 ex manuel... also another problem... Where the heck is the hole in the fire wall... There was a giant rubber thing that is covering the metal which i could not figure out how to get off
Old Jul 14, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
Old Jul 14, 2005
MegaHurtz's Avatar
the giant rubber thing IS the hole in the firewall, the wire goes thru it
if you are pulling on your panels and they are not coming off, pull harder
Old Jul 14, 2005
Rudy's Avatar
Rudy is an unknown quantity at this point
Maybe a picture of what is underneath will help:
http://www.softwork-orange.com/other...ic.com/c_1.jpg
Old Jul 14, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
the grommet for the fire wall is easy to find if you get on the pass side floor pull the kick pannel and the under glove box pannel then pull the carpet back from behind the center console and you will see a grip of wires follow them.
Old Jul 14, 2005
jb1004's Avatar
jb1004 will become famous soon enoughjb1004 will become famous soon enough
To remove the boot around the shifter all you have to do is pull up. The diy is for an automatic and it's not quite the same. Instead of pulling up using the little hole that is accesible when you open the cup holders, just feel under the boot at the front and back. Essentially these two spots are handles to remove this panel. Just make sure you've removed the shift ****, then grab the two spots under the boot and pull up. The panel should then pop up and the rest of the diy is the same as the one for the automatic. As far as the hole in the firewall just pull up the carpet on the passenger side and it's towards the center console. I just put a coathanger through it from the inside to the engine compartment and taped my amp wire to it using duct tape. Then you just pull the coat hanger back through and voila you're in business.
Old Jul 14, 2005
2k5EP's Avatar
Thanks guys... lol i found the hole
Old Jul 14, 2005
MegaHurtz's Avatar
^^ was she mad that it took so long?
