help?!
Old Jun 21, 2005
HondaLuver's Avatar
Its a celebration bitches!
help?!
well i installed my friends radio in her 95 accord. she had a aftermarket radio and a tape player with a 12 disk in the trunk, she wanted a cd player in the cabin, so she decided to get her cousins old cd player. i hooked all the speakers up correctly. i got the constant 12 volt, ignition and grounds correct. now there i 1 problem, i still got the dash dimmer, and there is no where i can hook it up to. the dash lights are not lighting up at night and i know its this wire, but what do i do, do i ground it. i think the wire that is suppost to go on the stereo is missing on the harness.
what are my options, do i ground it... or can i splice it to something else, so it turns on the dash lights...?
Old Jun 21, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
What type of head unit is it? Some head units (cheaper pioneers along with others) don't have an illumination wire. No you don't ground it.. You probably blew the fuse for the dash lights because the wire was already grounded. Replace the fuse, and run a wire from the dash lights to the wire. Or just tape it off and dont use the illumination wire.
Old Jun 21, 2005
MYK1013's Avatar
yeah, check the fuses.
Old Jun 21, 2005
HondaLuver's Avatar
i did check the fuses, i checked them like 5 times
Old Jun 21, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Did you eyeball them or use a meter on them?
Old Jun 21, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
cap it off or get a real deck
Old Jun 21, 2005
HondaLuver's Avatar
Lol. I pullled out the fuse and looked at it. Ill put It on a volt meter. If I do wire it back up where would I hook it up 2? My friends said they want a real radio...lol. And a professional... Lol. They person who previously installed the previous radio cut the stock harness... I was like. Wtf..
Old Jun 21, 2005
MegaHurtz's Avatar
as per the rules, please follow the guidelines on craeting descriptive thread titles or the thread will be locked
oh btw... locked
