AMP keeps blowin fuses
Old Jan 26, 2002
Waldo's Avatar
Waldo is an unknown quantity at this point
im helpin my friend install his kenwood amp and it keeps blowin the fuses on the amp and once the fuse on the wire from the battery dunno what to do any suggestions????
Old Jan 26, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
Check your ground, it can be a bad one that keeps shorting out the fuses
Old Jan 26, 2002
mohawkboom's Avatar
What Ohm subs are you hppoking it up to?
Old Jan 26, 2002
Waldo's Avatar
i think i got it i had the wrong amperage fuse from the battery i think im gonna try it now i have another prob though i need rca jacks to the amp with a stock system im gonna search the board for the problem but if you wanna save me the trouble just post it for me thanks
Old Jan 26, 2002
mohawkboom's Avatar
What you need is a high voltage line adapter.. Turns your speaker signal into an RCA output. Little black box.. runs about $25 at Radioshack...if iy'd just to power subs don't worry about quality..you'll never know the difference anways
wingsfan19
Oct 1, 2015 03:45 AM
JMKendrick
Sep 16, 2015 06:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
