turn-on/turn-off Pop and it's remedy . . .
Old Jun 3, 2005
Zerostatic's Avatar
Zerostatic is an unknown quantity at this point
I hear a pop coming from my solo 12 inch sub (which is connected to a mono amp)
I hear it in the following conditions
When the volume transistions from 1 to 0, or from 0 to 1
When I'm listening to the radio and I go from one of my preselects to another (i.e. during that momentary pause)
When I switch sources (i.e. go from radio to CD and vice-versa), (again during that momentary pause)
From a couple of searches I've done I've seen people have similar problems and they called it turn-on and turn-off pop, and it happens when the headunit signal shuts off before the amp or when the amp turns on before the headunit has a chance to turn on.
1) Does this sound like what i have?
2) I saw some turn-on and turn-off pop eliminators for sale on a couple of sites. Would this do the trick? (I read that you can make them to but I'd rather buy them already made, they're pretty cheap).
3) Could it be anything else, I don't want to spend money and time getting those eliminators and find out that they don't fix the problem.
4) Does it seem wierd that I'm having these problems now because I have a pioneer HU, a pioneer Amp, and a Pioneer Sub. I would think Pioneer would engineer their parts so at least they'd work together? Also I had a previous set-up with the same HU and a JBL amp and a pair of smaller Pioneer subs and I never had these issues before
Old Jun 3, 2005
paradoxblue's Avatar
when i had popping from my doors it was the day that my amp turn on wire got cut and i jsut had the amp running off the contast.. haha so it was always on
i got a pop from the speakers teh amp was on when i hit the power locks or turned the car on..
Old Jun 3, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
is your amp gain up all the way?
Old Jun 4, 2005
joescivic02's Avatar
Abercrombie and Fitch
OMG i have the same prob!!!!!!!!!!!!!!!! what is it guys??? when my HU turns on there is like a subwoofer sound constantly and when i turn from 01 or 1-0 i hear th pop........ and when i leave it on volume 0 the subwoofer keeps on beating nasty...... i changed every single of my wires........... the only thing i can think of is my hu now...
Old Jun 4, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
If your sub is beating when the volume is at 0, you probably ran the power wire along the same side as the RCA's. The power wire is interfering with the RCA signal. try running those on separate side of the car. that should fix the problem.
Old Jun 4, 2005
SpecialEdCivic's Avatar
SpecialEdCivic is an unknown quantity at this point
Exactly.. if you are having teh same problem with speakers move the speaker wires from teh power also.
Old Jun 5, 2005
ASD CiViC's Avatar
ASD CiViC is an unknown quantity at this point
whut type of deck do u have in your car??
Old Jun 28, 2005
my power is on the pass. side and my rca's and remote is ran along the drivers side......... i stil cant figure it out
Old Jun 28, 2005
pr0vidence's Avatar
pr0vidence is an unknown quantity at this point
How loud is it? It is probably just the amplifier (dis)engaging.
Old Jun 28, 2005
MegaHurtz's Avatar
sounds like youe head unit cuts your signal off when there is no signal going through (like when your vol is at 0 or when there is no signal between the few milliseconds when you change tracks/presets) and then turns it back on when signal wants to be transferred again. this is done in some decks (alpine is the only one that I can think of off hand) to eliminate floor noise when there is no signal being played through the speakers. unlikely that it is turning your amp off, although you will want to check that.
this could be a tricky fix if the amps do not turn off. if that is the case as i suspect, i could not see a turn on/off pop eliminator being any help. if you can't live with it, then a creative solution will have to be used, probably professionally done, unless you are skilled in the ways of electronics
Old Jun 29, 2005
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Try putting a cap on the speeker. Sometimes it will grab that little power spike
Old Jun 29, 2005
Ed's Avatar
Ed
That might not work, since it could act as a high or low pass capacitor, depending on connection.
Old Jun 29, 2005
rulebreaker's Avatar
rulebreaker is an unknown quantity at this point
Take a look at this article and try the following if you can
http://www.crutchfield.com/S-g4G6Pg1...ech/kb327.html
Try putting a diode inline on the turn-on lead, then put either a 470uf or a 1000uf cap in parallel. This will delay the amp turning on, and should get rid of the pop. The cap has to charge up before it'll allow voltage to pass to your amp remote. What you want to do is experiment with different value caps so that the radio comes on before the amp. You should be all set.
Old Jun 29, 2005
MegaHurtz's Avatar
that is, IF it is the remote, which I doubt
find out if the remote is your problem fiorst
Old Jun 29, 2005
D5cIvIc's Avatar
i use to have that problem on my old ALPINE, but since i got the PIONEER in dash. the problem jsut went away. i still don't know how, but it did. as for the sub still beating when the head unit turned off, that happened to me when i was running subs on a stock head unit. i found out hte problem was that when the stock head unit was turned off, power was still being sent to the subs for some reason.
Old Jul 1, 2005
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
was the remote wire from the amp run to the switched output of the head unit?
Old Jul 3, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
I cant see this being an Alpine problem, because i've had 3 Alpine headunits and none had done this.
Old Jul 3, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
I have a Pioneer Deck. My Sub only makes the thump when i turn off the car. Its silent when im switching pre-set radio stations, cd to radio, volume 0 to 1+,.
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
Whitexj
Sep 30, 2015 02:04 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
JJ291
Sep 2, 2015 11:49 PM
