Best Bang for the Buck
I know this has been covered before but i couldnt find an accurate enough thread so...
I have roughly 200 dollars and a 1000 Rockford Fosgate Power Amp, and im looking for the best 2 12" subs for this setup
Originally Posted by J187
You aren't gonna get **** for $200 if you want 2 subs. The only subs I know of that I would even consider, but havne't heard, are CDT Audio Cl series. Those are 89 ea.
you have a power RF amp? like a 1000bd or something? that amp is a beast, woofers like the JL W0 will die on that amp, lol. unless of course, you run it at a high impedance load, like 4 ohms.
if JL W0's are a consideration, consider the W1v2. I just heard that they are on back order from JL and wont be in stock until july/august. if you have a shop around that still has them, consider buying those. you should be able to get two 12 W1v2's for $200 (two 13 W1v2's should run $300 a pair). if you're lucky, you might be able to get a couple 8 ohm subs so that you can run them at 4 ohms.
i love the W1v2's, great subwoofer for the money, i'd buy them if i wanted an inexpensive, shallow mount, small enclosure driver.
check out blaupunkt sub's they hit hard and arn't too expensive, and not everyone has'em..
http://www.crutchfield.com/S-opsjada...arch=blaupunkt
I just installed 2 10W1V2's last weekend and I'm loving it. They may not hit as hard as some other subs in that price range, but you'll definitely feel a good thump. Not only that, it's a good quality bass; very tight and precise.
I listened to a few other subs the sale guy was trying sell me, and although they had more power, none of them sounded near the quality as the w1's. Just my 2 cents.
You might want to consider one Ascendant Audio Avalance 15". Due to a liscencing issue with Adire Audio they are blowing out their current inventory at crazy prices. The 15" Avalance is $225. Check out www.ascendantaudio.com. I just ordered one of the 12"'s and I'm eagerly awaiting its arrival. The Avalance series will take that 1000 watts without a problem.
Originally Posted by LowRYda03ex
so 1000 watts wouldnt be too much for the Wv1's?
my local shop did a SQ car, put two 12w0's in a vented box with a JL 500/1 on them, they take a massive beating, pound hard, and sound great to. i think the W1v2 can handle it if the W0 can.
i worked at a car audio spot until about 2 weeks ago and i would say get a boston acoustics g21244 but if its one of the old t10001bd with heat sink and not the new powers series amp u should go with a dual 2 ohm type "R" alpine but if its a new power series rf its not 1 ohm stable so do the g21244
Originally Posted by spo122
infinity reference 12 hold up to 1200 watts and are at circuit city for 89.99 i had two on a kicker 1200.1 in a ported box and it was banging
i dont think u'll get much more from a 15 instead of 2 12's... i think the power in a 15 is distributed to wide in a 15 and they take up a lot of space if ur planning to do a good trunk job... i got my 3 10's w/box for 200 and they are awesome, some random brand but they knock
TheRiddicles
Sep 21, 2015 03:34 PM
Galbir
Aug 31, 2015 07:05 PM
bhollie
Aug 19, 2015 01:07 PM
brainwashedmc
Jul 27, 2015 10:05 PM
