sound system help.
Old May 7, 2005
Rennen's Avatar
New Mod on the Block
sound system help.
hey everyone. i have a pioneer headunit model # DEH-P4500MP. whenever i turn on my stereo it sounds like its crap, sorta like the speakers are blown. but when i fade the sound all the way to the rear, it sounds perfect. i know its not my head unit because i put back my stock cd player and its still doing it. and i know its not my speakers because they sound perfect when the sound is faded all the way to the back... im so confused... any input would be appricaiated. thanks.
Old May 7, 2005
takumi's Avatar
takumi is on a distinguished road
Maybe your front speakers are blown.
Old May 7, 2005
Rennen's Avatar
they're not. i've hooked them up to the back to see if the were blown, but they worked perfect.
Old May 7, 2005
fonto's Avatar
The LA Clipper
maybe you speaker wire is touching metal?
...are you using an amp? Is you gain set to high?
...did you wire it yourself? How are the speakers connected?
Old May 8, 2005
Rennen's Avatar
speaker wire could be touching metal, i'll check in the morning. amp is hooked up to 2 12" pioneer subs. no amp for the mids or highs, they are hooked directly yo the headunit. and yes i did it myself. when i installed the speakers, i just cut off the plastic adapter thing and connected the speakers with the wires that came with them.
Old May 9, 2005
Big Rob's Avatar
I'm taking over!
Big Rob has a little shameless behaviour in the past
How do your rear speakers sound when it isn't faded all the way to the rear? If the rear ones sound bad when it isn't faded all the way to the rear, then I don't know what the problems is. If they sound fine then check your wiring in the front. Your speakers might be out of phase.
Old May 10, 2005
Regularjoe's Avatar
Regularjoe is on a distinguished road
Good call .... that could totally be the problem. If they are out of phase it will make the sound all unfocussed and the bass won't be as good either.
Old May 10, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
EDIT - Comment deleted
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Linda0818
Apr 23, 2015 11:30 AM
supercivic01
South
Nov 30, 2001 11:27 AM
BabyLX
Nov 16, 2001 05:53 PM
JDock
Nov 9, 2001 08:53 AM
