The Truth About Capacitors
Old Apr 21, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
Ok, first, and foremost, one of the main reasons that I am posting this information is because of recent debates had on caps. People saying that caps help keep voltage constant around 14.4 V, etc. I'm sick of reading stuff like "get a cap, it'll help blah, blah, blah..." The following information is excerpted from CARSound's great cap debate thread, or whatever they choose to call it. The excerpted portion that I am pasting here is all information posted by Richard Clark, whom is a moderator there, and one of the godfathers of car audio. He even offers $5,000 for anyone that can disprove him, but the catch is you have to have factual scientific data to prove it. There are several books that both he and Dave Navone co-authored about car audio, and have the data included. I' sure there is a PDF somewhere as well, but this is a long read of information that proves the "theorys" incorrect, and untrue. Read through the whole thing, and gain an understanding of caps, and their use, and what they actually do before trying to debate this information. If you have a dispute with it, perhaps you should contact Mr. Clark. And now, for what you've all been waiting for, and yes, I'm well aware that it's real damned long:
Lesson 1
Ok “powertrip” how about we have a discussion in basic electrical theory? At the end of this thread you should be the one that can explain to the world that according to ohms law it is impossible for these things to do any good. That is of course if you can admit that they do obey ohms law. We will do this a little at a time so how about you humor me and stick to my questions. We will do them a couple at a time so everyone can follow along. Let’s do a little calculation. Suppose we have a resistor that is .017 ohms (seventeen milliohms). I think that is what you say the ESR of the giant caps is.
The ones I have seen have measured higher but I will give you the benefit of the doubt. According to ohms law how many volts are dropped across .017 ohms if 100 amps of current are flowing? How about if we up the current to 300 amps? Let’s establish the answers to these questions before we go any farther. If we can't agree on the answer to this there is no hope we will ever get to the truth.
Lesson 2
Thanks David you are exactly right. If anyone wants this explained please ask David to clarify it. If everyone is going to follow this and understand fully the final conclusion it is important that no one miss any steps. There will be about ten lessons. Since power trip has left the building we will continue with the rest of the class. ESR stands for equivalent series resistance. This means exactly what it sounds like. It means that if we have a source of voltage it will behave exactly as if it has a resistor of the same value in series with its output. An amplifier has ESR, a power supply has ESR, a battery has ESR, and yes, a cap has ESR. Components have ESR’s because we do not have perfect conductors to make things from.
And now for the homework. Last night we learned that if 100 amps flows through .017 ohms there will be a voltage drop of 1.7 volts. And if the amp flow increases to 300 amps the voltage drop will increase to 5.1 volts.
For the sake of theory only let’s say we have built the largest cap in the universe and it has billions and billions of Farads. Its plates are made of a newly discovered material we'll call unobtanium. This new material has no resistance therefore our super cap has an ESR of ZERO ohms. We then charge the capacitor to 14.2 volts. We then place a resistor with a value of .017 ohms in series with one of the terminals of this cap. The question is: If we place a load that draws 100 amps from this cap what will the resulting voltage be on the load side of the resistor? What will the voltage be on the cap side of the resistor? What about if we increase the load to 300 amps? What will the voltages be on each side of the resistor?
Lesson 3
Ok now that we have studied ESR and understand what it is and it’s effect on the working of a circuit we will move on to another subject. But don’t forget about ESR as it is one of the important final building blocks in our search for truth about caps and we will come back to it. Today we will review the important concepts about total energy storage in a device like a cap. This has been covered in earlier posts (and I will say quite correctly) but I am going to expand on it as well as reiterate it for those who did not get to read it. Besides, I think I can simplify it a little.
In electronics, we measure power in watts. Wattage tells us how much work a device can do. But a wattage rating does not tell us anything about how long we can sustain that work. When we add the element of time to our wattage, we use a value we call Joules. A joule is a watt second. This means that one Joule of energy can provide a watt for a second. Ten joules can provide a watt for ten seconds or ten watts for one second or five watts for two seconds one hundred watts for a tenth of a second, and so on.
The formula for determining the total joules stored in a capacitor is very simple. We take one half the capacitor’s value in farads and multiply it times the squared charge voltage. For example a one farad cap charged to 14 volts would be .5 X (14x14) = 98 or .5 X 196 = 98 Joules. A 20 farad cap charged to 14 volts would be 10 X (14x14) = 1960 Joules.
There is a very important concept to understand about energy storage. A capacitor actually stores electricity.
Batteries don’t. Batteries have the potential to produce electricity by means of a chemical reaction but caps actually store electrons on their plates in the form of an electrostatic charge. In our next two lessons we will learn why this is important to know.
But first, the homework. This is a “think about it question”. We have learned that a Joule is a watt second. A Yellow top battery is rated at 65 amp hours. This means it can provide 65 amps for an hour. The question is how many Joules does this represent? Since this is a thought question, it would really help if whoever answers would show us your math.
Lesson 4
In the actual real world the voltage of the battery would drop a little from its open circuit voltage of 12.8 volts with a 65 amp load. In the case of the yellow top its actual voltage at 65 amps is about 12.2v when fully charged. By the end of the hour it would be down to about 10v. If we use 11 as an average our answer would be........ 2,574,000. Now that's still a lot of joules! Now actually this is not enough to totally kill the battery but at this point there isn't much left in it. This brings us to a very important fact. The energy in a battery will be depleted almost completely by the time it is down to 10 volts.
Lesson 4 (continued)
By the time we have removed those 2.5 million joules from the battery it probably doesn't have more than a hundred thousand joules left. We can almost totally deplete the battery's energy and never drop below 10 volts. This is because the battery doesn't store electricity. It stores chemicals. A chemical reaction produces the electricity. Storing actual electrical charges is very inefficient.
Look at our poor capacitor. Even if we made one as big as a battery it would still only be good for perhaps fifty to one hundred thousand joules---less than that left in a nearly dead battery. But if that were not enough there's more bad news. This exercise will be tonight’s homework.
A capacitor is like a gas tank in a car. The pump can only remove gas down to the pickup point. Any gas below this point can never be removed by the pump. If we charge a 20 farad cap to 14 volts we know from previous lessons that it will contain 1,960 joules. If we use that cap in a system and load it till it drops to 10 volts along with our battery how many joules will we have removed from the cap? How many joules will remain in the cap that we can never benefit from if our system never drops below 10 volts?
Lesson 5
In our last lesson we learned that caps actually store charges on their plates. And of the 1960 joules stored in a 20 Farad cap, 1000 of them sit at a potential below 10 volts. This means there is no way they can ever be used by an operational audio system. Today we will look at another loss factor. It has to do with the loss factor due to the ESR of the cap.
We have already studied voltage drop due to ESR but now let’s view it from an energy/watts standpoint. Let’s clarify things. The power delivered to the stereo by the battery and alternator bypass the cap. They merely flow by its terminals. If the cap charge is lower than the battery/alternator potential current will flow INTO the cap until it reaches equilibrium with the Battery/Alternator. If the B/A potential is lower than the charge potential of the cap current will flow OUT of the cap to the battery and or the amp.
Always remember that voltage always flows from the highest potential to the lowest potential, just like water. Current does not however flow into the alternator even if it is lower than the battery and cap because it has diodes on its output that only let current flow FROM its output. Now whenever any current flows into or out of the cap it must pass thru the ESR of the cap. The resistance is really distributed throughout the cap but it behaves just like it was right on the output terminal as in a series circuit location in the circuit loop does not matter. Now suppose our 20 farad cap is charged to 14.2 volts and we place a load on its output. This load is the same one that we used in lesson 2 to cause 100 amps of current to flow from our unlimited capacity cap. Only now we have our smaller 20 farad cap.
Lesson 5 (continued)
We know that if 100 amps of current flows out of our cap, those 1.7 volts will drop across the ESR of .017 ohm. This will cause the output to drop to 12.5 volts just like it did with the unlimited cap.
This means that the load (100 ohms resistance) will be consuming 1250 watts from our cap. 12.5 volts x 100amps = 1250 watts. The total wattage output produced by the cap is 1420 watts. 14.2 volts x 100 amps = 1420 watts. Unfortunately 170 watts of power will be lost in heat in the ESR of the cap. This represents a loss of 13% of our total usable joules (960) at this point. Now tonight’s question is if we increase the current draw to 300 amps (300amps x 14.2volts = 4260 watts), how many watts will be dissipated in the ESR of the cap and what percentage of the total 4260 watts does it represent? Of our total usable 960 joules, what percentage will be left for the stereo?
Lesson 6
Ok before the next lesson let’s review lesson five. When I checked the posts no one had the correct answer of 56% but some were close. The important part is that everyone seems to understand the loss mechanism. From lesson five we see that the energy we can get out of a cap is inversely proportional to the rate that we try to take it out. This is because the ESR that is in series with the output stays constant regardless of the load. At very high power levels, this ESR can amount to a sizeable amount.
In an earlier lesson we learned that the ESR causes a voltage drop proportional to current flow. When voltage is dropped across a resistance heat is created. Lesson five taught us that with 100 amps (flowing from a cap with .017 ohm ESR) we lose 13% of our joules as heat when we try to remove them. If a cap has an ESR of .017 ohms, and 300 amps flows we will lose 56% of the stored energy when we try to remove it. In our giant cap example with 300 amps of current, we will lose this as 1530 watts of heat. This is the same loss mechanism that causes a battery or amp or power supply to get hot when they are delivering high power levels. Virtually all voltage sources have at least some ESR. At this point we should have a good understanding of how ESR affects a component. The next logical thing to cover is ESL.
ESL stands for equivalent series inductance. Just like the ESR it can be modeled as an inductor in series with the output of our capacitor. Now everyone in car audio knows what inductors do. They resist a change in current flow. Their most common use is in speaker crossovers. When used in series with a woofer they let the slowly changing low frequencies pass, but stop the fast changing high frequencies. The reason an inductor does this is because it behaves like a resistor that changes value with frequency. Unlike a capacitor that decreases in value with increasing frequency an inductor decreases in value with decreasing frequency.
Lesson 6 (continued)
Now I have been told that the ESL value of the giant cap is 0.2 mh. Somebody check my math but I think this would put the reactance of the cap near .063 ohms at 50 Hz. This means that if we wanted to refresh our amps at a rate of 50 Hz (seems reasonable if we were playing bass real loud) our ESL of .07 ohm would be in series with our .017 ohm ESR for a total value of .08 ohms.
Now we know from ohms law that if we try to get 100 amps through .08 ohms we will have a voltage drop of 8 volts and at 300 amps the drop would be about….well it’s pretty clear that we will be left with less than a fraction of a volt if we start out with only 14.2. Is everybody still with me? I know it’s not good news but I’m not making this stuff up.
Now for tonight’s lab lesson to prepare us for lesson 7. Tomorrow, I will post the results of the following test. If you want to check me, go to Radio Shack and buy the following: Bulb # 272-1127, Socket # 272-360, and a nine volt alkaline battery. For the battery a Radio Shack is ok but a Duracell is better. Make sure it is fresh!!!!!
Wire the socket and connect it to the nine volt battery and record how long the bulb stays lit. Be prepared to wait for a couple hours. Charge a giant cap to 14.2 volts and do the same with it. Be prepared to wait about an hour. Charge a 1 or 1.5 Farad cap to 14.2 volts and do the same. This will take only a few minutes. Record the times and we will discuss the importance of this in our next lesson.
Lesson 7
Ok in last lesson I left everyone with instructions to duplicate the results of the test I am going to post tonight. The purpose of this test was to put the capacity of even a giant cap in perspective. As I have pointed out in earlier lessons storing electrons in the form of a charge on a plate is not really very efficient. Some folks think we should stand in awe of a value like 2000 Joules. Well our test tonight puts some reality in this value. If we perform a test like described in the end of lesson 6 we come up with the following results.
1.5 Farad cap lights the bulb for about …………5 minutes and 28 seconds
a giant cap lights the bulb for about……………. 54 minutes
a nine volt alkaline does so about …………………. 2 hours and 14 minutes
did anybody get results similar to these…….are we in agreement on these numbers ?
Lesson 7 (continued)
As for the relationship of these numbers, each of these units has a higher ESR than the previous one. The highest ESR in the group was the nine volt battery. It actually has enough energy to light the bulb far longer but since its ESR is fairly high it loses a lot of its energy as heat internally. But even still it should be apparent that it holds more energy than the giant cap and a whole lot more than a 1.5 farad unit
For now I do not care to concern ourselves with the meaning of this ---we will cover it in the closing. Before going on let’s review a few facts. In lesson 3 we learned that a giant cap can hold 1960 joules at 14 volts. In lesson 4 we learned that only 960 of them sit at a potential above 10 volts. In lesson 5 we learned that if we want to use them at a rate of 100 amps we will lose 13% of the 960 that are left.
If we use them at a rate of 300 amps we will lose 56% of the 960 which will leave us with only about 500 usable joules. And these losses are only for the ESR mechanisms—they do not include the ESL mechanisms that could actually be higher if the demands are quick enough.
It has been suggested that the purpose of these giant caps is to provide quick energy. It has also been suggested that they are for slow energy.
I am not sure what is being claimed so I guess I need to cover both situations. As for slow energy I think the previous test could put that thought out to pasture. For long term energy one of these units is less useful than a nine volt battery and to compare it to a car battery is really useless. After all what good is 500 useable joules when we have over 2 million in the car battery? It should be obvious if one of these devices can be of any use at all it will have to be able to provide energy faster than a car battery. But before we get to that issue lets cover the behavior of alternators and batteries under dynamic load conditions.
Tomorrow is Saturday and I will have time to measure the response time of a few alternators. This will enable me to model my closing explanations more exactly. I will post the results of these tests tomorrow night.
Lesson 8
For this lesson I have done some actual measurements. Here are the test conditions: To measure voltage we used an Audio Precision with a DCX module. It is accurate to three decimal places. For sample time we chose 40 samples per second. For the non audio system test I used a KAL carbon pile load tester. It can do power tests on 12 volt charging systems up to 1200amps continuous. The audio system consisted of a couple of Rockford 1100 amps bridged into four ohm nominal speakers. The alternator was a stock Delco 80 amp CS type unit.
Its case temperature was monitored by a Raytek ST2L IR sensor. Engine speed was regulated with a Thexton #398 IACV tester. The music material was the SPL track # 30 from the IASCA competition disc. The battery was a Stinger spb-1000. All voltage measurements were done directly at the terminals of one of the amps.
Chart 1 Alternator/cap/battery test with 200 amp dummy load
For this test we monitored the voltage of the car with the stereo turned off. With the car running the voltage can be seen to be stable at about 13.7 volts. After 22 seconds (The horizontal scale is 100 seconds-10 sec per major division) we applied a 200 amp load. The voltage can be seen to drop to 11.6 on both traces. This test obviously exceeds the ability of the alternator to keep its regulation set point so its voltage falls. The drop can be seen to be nearly instant (steep curve) until about 12.5 volts where the battery starts to supply a significant amount of the power.
Ultimately the voltage drops to 11.6 and at 26 seconds we turn off the load. The voltage then starts to rise to the regulator set point as the battery is recharged (yellow curve) and as the battery and cap (green curve) are recharged. At a time of 50 seconds I turn the motor off so the alternator stops. The voltage then droops down to the float voltage of the battery—about 12.7. The only reason for the small difference at 50 seconds is because I couldn’t get the timing of the engine shut-off exactly the same every time. I did it several times and these two are within one second. That was as close as I could get it.
I am able to see no difference from these measurements. There are microscopic differences but I believe they are due to the alternator temperature. Alternator regulators are usually temperature sensitive. As they get hotter they tend to fold back. For this reason we let the unit cool off between each test and closely monitored the case temp throughout the tests. For this reason I believe that none of these measurements are meaningful to more than a couple tenths of a volt.
Chart 2 Music tests with an audio system
Note: Between each test the alternator was allowed to cool and the battery was charged until an automatic charger said it was topped off.
Purple curve
For our first test we played the system with the engine off and no cap. The result was the purple trace at the bottom. We played the system as loud as we could get it that seemed to produce no audible distortion. This was track 30 of the IASCA disc. It starts off with fairly low level sounds for the first 34 seconds. In order to insure the electrical system was stable we did not start the measurement until we were 20 seconds into the song. This means that our 0 starting point is: 20 on the CD counter. The battery was able to maintain its voltage just below 12.5 until the loud bass hits at 34 seconds (14 seconds into our chart) At this time it dropped to about 11.5 and had a few large variations due to the music. According to the computer calculations (third chart) the average voltage for this test was 11.7volts. This test was done as a baseline for the following tests.
Yellow curve—no cap
For this test the volume was left as it was for the baseline test. The engine was started. Notice that at low volume the alternator was able to maintain about 14 volts. When the loud music hit the voltage dropped to about 12.5 where it remained except for a few short moments where it actually climbed back to over 13.5 volts. The computer averaged calculations for the average voltage during the 100 seconds of this test was 12.973 volts.
Red curve—cap added
This test was identical to the previous test except the cap (15 farad type) was added 6 inches from the amp with 4 gauge wire—no relays or fuses. The red curve seems to overlay the yellow except that the actual peaks don’t rise as fast or as high during the brief quiet moments. I feel this would be due to the alternator having to recharge the cap. The voltage on loud passages hovered around 12.5 volts. The computer averaged calculations for this test show the average voltage to be 12.878 volts. I see no meaningful differences with or without the cap. I certainly don’t see the voltage sitting solid at 14 volts.
One note I might add is that this was a two thousand watt system driven right to clipping and the average voltage stayed above 12.8 with a stock 80 amp alternator. Under these conditions the battery would never discharge!
The green and blue curves were done just for kicks while we had the system set up. In both these tests we turned the volume up until the system was very distorted. This placed a severe load on the alternator and caused the voltage to dip as low as 12 volts. The curves seem to follow each other so closely that unless you have a good monitor it is doubtful you can tell there are two curves. The average voltage for these two curves was both 12.277 and 12.295 volts. If this volume were sustained for very long periods of time this battery would discharge.
Any questions? Please ask -- I will give everyone a chance to ask them before I sum this all up in lesson 9.
Lesson 9
Now that we have had time to study theory in each of the 8 lessons and the results of the actual tests on a real system it is finally time to bring this discussion to a close. Unfortunately, when this thread started I was unable to explain the concept, as it was obvious that many of the people posting responses just didn’t have a good grasp of the way things really work. Those of you who have taken the time to follow the lessons should know by now why I was so frustrated at the arguments that were so illogical. It is important to keep in mind that this is a technical forum, not a marketing forum. I do not care or want to know about companies or brand names.
Nothing I have said was ever meant to disparage a particular product or company and I would appreciate it if in the future we could always keep that in mind. We should be able to discuss the merits of radial vs. bias ply tires without caring if they are made by Michelin or Goodyear.
In car audio we have little choice of how we are going to power our systems. Presently we have only four things that are practical. Each of them has its own characteristics that incorporate good points and bad points.
Let’s review them
The battery--this device has the ability to provide a very large amount of current. But due to its nature the current is provided at a voltage that is less than optimum –at least for a high powered stereo. Since its float point is 12.8 volts if fully charged, it can provide current only at voltages that are proportionally lower than 12.8 Volts.
The alternator—this device is electronically regulated at a point that allows it to recharge the battery. The alternator is usually designed to output voltage in the 13.8 to 14.5 volt range. Because its output is actively regulated it attempts to maintain this voltage with varying load conditions up to the point where it’s output cannot keep up with the load at which time it’s output drops off very rapidly. While relatively tight regulation is the strong point of the alternator it’s weak point is that it simply is not practical to obtain one that can provide large amounts of current like a battery is capable of.
The capacitor. The advantages of a cap are that it can charge up to whatever the highest voltage source in the system is, (in a car this would be the alternator) and provide current at this elevated voltage. The down side of a cap is that it cannot store very much total energy and only a portion of this energy is available at a usable voltage potential. The fourth type of device is an electronic voltage regulator. These devices have not been part of this discussion so I will pass over them for now.
Now modern car audio amplifiers are capable of consuming enormous amounts of power. Even with efficiencies in the range of 60% to 90% an audio system is capable of drawing hundreds or thousands of amps from the cars electrical system. Typically, the audio system is larger than any other electrical device in the car including the engine starter. Fortunately for the car, the demands of an audio system are rarely continuous in nature. The very nature of music rarely demands more than a duty cycle of 10% to 20% from a power standpoint. This means that the audio system is demanding short term, but repetitive peaks of current from the electrical system.
The primary source of this power is the alternator. It should be considered primary for two reasons. The alternator is the only first generation source of power. It ultimately provides all the power for the system either directly or indirectly by restoring power to the battery or cap. It is also primary as it is the power source with the highest voltage potential. In an electrical system current always flows from the source of highest voltage to circuits of lower of lower potential.
All three devices can be used in a system to great advantage. But the dynamic conditions present in a music system determine the role each device plays and to what degree. To understand this lets consider a low current drain condition. In this scenario the alternator will be at or near its set point.
This voltage is designed to be high enough to charge the battery meaning it will be one or two volts above 12.8 volts. This means that the battery will actually be a continuous load on the alternator and provides no power to the system. The size of load it presents is determined by the state of charge of the battery. The higher its state of charge the smaller the load will be. A cap if present in a system in this state will present a load for a finite amount of time until its charge voltage reaches equilibrium with the alternator.
Unlike the battery, the cap will cease to be a load after it is charged except for a factor known as dissipation, which for all practical purposes can be ignored in this application unless it is excessive. Under these circumstances, as long as the alternator can maintain its set point, it will provide all the power for the music system and the rest of the cars accessories. The battery and cap may as well not even be in the car.
Now if we increase the current demands of the music system to an amount that taxes the alternator its output voltage will begin to drop. Even so the alternator will continue to be a source of current to the system –i.e., the car, music system, and battery. It is at this time that the cap will begin to discharge and begin to augment the alternator as a source of current. The degree to which it provides current to the system is dependent on the actual voltage at the alternators terminals. Only when the alternator begins to drop below the caps charge potential does current flow out of the cap.
This is a continuous process and the current provided by the cap tries to maintain the voltage at its charge potential. The degree to which it can do this is dependent on two things. The current provided by the cap is limited to the total capacity of the cap and any series reactance’s (resistive or inductive components) that are part of the cap. The instant the cap starts to output current its charge potential begins to drop.
Now just what can we expect the cap to provide? Suppose we happened to have a cap charged to 14 volts, with a total reactance (made up of either resistive or inductive components) of about .017 ohm. We could figure that at the first instant of discharge it could provide ten amps at 13.83 volts. Of course if we were playing the system at a level enough to load our alternator, ten amps is not likely to provide much relief. But perhaps 30 amps might help—at this modest level our cap could begin to provide current at a potential of 13.5 volts. (lesson 2).
Of course this voltage level would drop at an exponential rate commensurate with the discharge curve that is standard with caps. No doubt the cap could help out a hundred amp alternator with the addition of an extra 30 amps even though it might be for only a brief instant. But it is sort of interesting that at even this modest power level of 130 amps (100 amps alternator + 30 amps cap) the cap is unable to maintain the voltage at 14 volts.
Of course in this scenario we are sitting at 13.5 volts for a brief instant and our poor battery is unable to help at all as its potential is at a lowly 12.8 volts. In fact the battery is still a load on the system!
Now what if we get serious with our stereo and we really crank it up? Lets say we have something like a manufacturers demo van with lots of amplifiers that can draw hundreds of amps on musical peaks. Lets pick a nice round number like 500 (“Cade” said 490) amps. Lets say we have a 200 (“Cade” said 190) amp alternator. Typically such an alternator can maintain a voltage near its set point up to perhaps 80% of its rating-after which its voltage begins to drop as it provides large amounts of current. As I am not familiar with all the different alternators lets just assume these assumptions are close and our alternator is putting out 200 amps. Well our amplifiers in an instant are asking for 500 amps so what happens?
In any constant voltage system when the current capability is exceeded the voltage drops. So let’s say our alternator voltage starts dropping. What does our cap do? Since its charge potential is at 14 volts it starts to discharge and provide a source of current. Since the cap is now sharing the load with the alternator it is called on to provide what the alternator can’t—that would be 300 (see footnote) amps.
What happens to the terminal voltage of our cap when 300amps is flowing? Well for starters, the voltage tries to drop nearly 5 volts inside the cap before it can even get out. Not in a short time but instantly. There is no time constant in the formulas for ohms law. They are instantaneous calculations! But wait. The voltage doesn’t really drop to 9 volts because we have our battery sitting in reserve waiting at 12.8 volts.
Our cap lets our poor alternator down as the voltage plummets and when things hit 12.8 volts our battery jumps in and starts to take over. The battery with its enormous storehouse begins to provide vast amounts of current until things lighten up for our poor cap and alternator. Of course we could add another cap to halve our ESR loss to only 2.5 volts but that would still cause the cap terminal voltage to drop to 11.5 volts.
Let’s see how many caps of this spec we would have to add to keep the voltage at 13.5 for even a few milliseconds. We would need a cap bank with a total ESL of about .001 ohm. Gee it looks like it would take over thirty caps paralleled to maintain 13.5 volts at 300 amps for even a brief instant. And let’s hope we don’t need to do this for long, as the total power contained in thirty units is only about what is in a dozen 9v alkaline batteries! (lesson 7)
It should be clear that if the voltage doesn’t drop the caps don’t do anything. The voltage MUST drop for them to start discharging.
Now, is it possible to have a steady 14 V because we added caps? I don’t think so.
Old Apr 21, 2005
tripledoublegs's Avatar
Euro-Spec
I think someone posted that before Popcorn
Or maybe it was on sounddomain.com...dunno
Good info though. Someone should make that a sticky
Old Apr 21, 2005
I've seen it on Sound Domain, Elite, Car Domain, and a few other forums, but not on here. Perhaps my search went awry somewhere, but the search feature on here sucks, so if it was posted, I can't find it.
Old Apr 21, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
I am still going to debate, that why do all the great caraudio company make the cap? Ofcourse i am not going to read all that or have knowledge to "prove it in science". All i know is. when i added a cap to my system, my dimming went away and the volt meter was reading higher volt's then before the cap... This is from your post above "People saying that caps help keep voltage constant around 14.4 V" that is not true because when the system hits the voltage drop's, but it will stil keep it closer to that number with the cap then without one.
Old Apr 21, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
So wait, Will a cap give me more bass?
Old Apr 21, 2005
are you referring to my post or???
Old Apr 21, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
I personally never stated that a cap with retain anything when it comes to voltage, The problem in this world is that people do not read all of someones thread, just the parts they want. A cap will store power and feed it when an amp pulls off of it. I debate that untill the end of time, I have made caps from aluminum foil and have tested them in 120v situations and 12v, both show that the cap holds power, they held what ever voltage I gave them briefly, I personally have a cap made for a air resanant transformer(tesla coil) and how it works is the cap stores the voltage and power untill it cycles for release thats how tesla coils put out actual visual voltage! Without a cap in the circuit this process is impossible! Caps have been around sincs the 1800's just used in a different arena. They are still around for the reason that they actually work. Now I know that the car audio industry is a bunch of viper's feeding on kids who dont know the difference, and thats too bad but if someone does not educate them selfs thats there problem.
Old Apr 21, 2005
J187's Avatar
NO, I'm just bustin' Pop's *****.
Old Apr 21, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
Old Apr 21, 2005
goodtimes's Avatar
what
Old Apr 21, 2005
You obviously did not read. I said it would not help it to keep the voltage near 14.4. As a matter of fact, I stated that it will do nothing, for more than a millisecond, anyway. The proof is in the pudding, and the pudding doesn't lie. Read the entire post I made above before you try to debate it, because it's very obvious that you did not read the entire thing. Debate it all you want. If you're that confident in your debate, claim your $5,000 frmo R.C.
Old Apr 21, 2005
Did you read my post first? Did you read the part around lesson 4 down. And, did you especially look at the exeriment involving the light bulb, cap, and 9V battery? You try it? Compare the current draw of the bulb to that of a car. Yeah, they store electricity, much of which is unusable, but it discharges so quickly, what's more feasible?
Old Apr 21, 2005
ncirom2003's Avatar
wow
ill read it all by monday and have the report on your desk by 5.
really is all this nescessary, people have different opinions, preferences, explanations, experiences so lets just all get used to being different and enjoy life OR YOU ALL WILL DIE!.(evil monkey finger)............ oh sorry ..............back to caps
Old Apr 22, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
laymen terms please, lol
theres no way im going to read that BOOK!!! lol
i am trusting no proof is needed and just want the short anwser, lol
Old Apr 22, 2005
burke420's Avatar
The World Is Yours!
my cap...sucks!!!!..and i wasted my money on it...get a alternator b4 you ever get a CAP....
Old Apr 22, 2005
Originally Posted by ncirom2003
wow
Yes, it's necessary because the vast majority of those opinions are incorrect, not fact based, and marketing ploys. 95% of people could not tell you how a cap functions, what it's purpose it, or likewise. People that want to learn, conversely, will read it. People that care about spending money that's unwarranted will read it. People that are lazy won't read it. If you're not going to read the entire thing, then please, save us time and space and don't reply.
Old Apr 22, 2005
J187's Avatar
If you took the time to post it, I'll take the time to read it. Either later on while I'm on the treadmill or much later while I'm chillin in my Ijoy chair.
Old Apr 22, 2005
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
so much reading.
someone give me cliff notes
Old Apr 22, 2005
ex_03's Avatar
Godlike member
Richard Clark
Moderator
Member # 8
posteddocument.write(timestamp(new Date(2004,5,9,10,48,0), dfrm, tfrm, 0, 0, 0, 0)); June 09, 2004 10:48 AMJune 09, 2004 10:48 AM
quote: Originally posted by stretch-d:
<B>
quote: Originally posted by Norm:
Everything connected to the alternator is a load, this includes caps and the battery. The magnitude of the load may change but it is still a load.
Yep...You're right. It will create a load, but it's very small and inconsequential when idle.
Unless you're referring to the load of restoring the depleted power from it doing it's job...Which in that case really won't be any more than the amp would have required from the electrical system anyway....It provides more stable draw which is much more beneficial than the small load increase that it adds by having it in the loop.
Edit: I've just read the post above and I understand it, but my system has shown benefits from having the caps (3 RF 1 farad). I have a 90 amp factory alt. and a mini-Yellowtop. A serious headlight dimming problem was reduced to un-noticeable with the addition of the caps.
If I had not noticed the benefits personally, I would easily be swayed by that powerful post. </B>
i can easily see how a couple "good quality" caps could help to protect against headlight dimming-------where in the cap lessons is there anything that would imply that it couldn't??????..............RC
So he say's they help in protecting against dimming!. Look at the signature RC (Richard Clark)???
just in case anyone missed this!
Old Apr 23, 2005
Yes, I never said they didn't help dimming. He didn't either. I am stating that that's all they're good for, so is he. They don't help voltage as lost of people like to suggest. They won't being your voltage reading closer to 14.4V. Read the entire post I made before you try to conflict any thing I've said or that he's written, or said. The effect is a millisecond on it. Is that millisecond worth the money spent? Why not upgrade with a measure that's guranteed effective?
Show me once, in anything he's written, where he said it doesn't improve dimming. Retard.
Old Apr 23, 2005
ex_03's Avatar
Godlike member
^^^Stay off the drugs son!!!
Old Apr 28, 2005
miktrain's Avatar
miktrain is an unknown quantity at this point
Half of what is in the original post is half-right. 90% is just smoke and mirrors to confuse you.
The internal resistance of the cap is irrelevant as it is in parallel with the circuit. Perhaps we should remove the wiring, battery and alternator they all have internal resistance! Maybe the speakers could go too they have more than any cap… so big they have it printed on them!
Any properly designed car amp should run on a nominal as opposed to the maximum voltage possible.
As the amp would have an internal switching power supply much the same as your computer except in reverse, to step up the voltage to a useable amount, 1 or 2 volts difference in the supply would hardly change the performance of a properly designed setup, as it would just compensate.
If it cannot run on 13 volts throw it in the bin.
Your 300-watt amp does not draw 300 watts from the system it delivers it to a low resistance load (speakers) and only then for a very short time between much longer low power periods.
If it was to draw 300 watts at 14.4 volts that is 20.833 amps or at 12 volts that would be 25 amps not really that much for most car alternators. What size are the fuses supplying your amp? If it was drawing 25 amps I would be hoping they were big at least 35 – 40 amps otherwise you would be replacing them often.
Do you realise that your amp only uses the top half of its power in the last 3 decibels before clipping starts. This is because you must double the power to increase the output by enough for the human ear to hear the difference in volume (3 dB). So most of the time you are only using perhaps 100 watts or so, the rest is just headroom for the loud bits, this saves both your speakers and amp from letting the smoke out.
The purpose of the cap is not to supply power but to smooth out the spikes caused by the switching power supply of the amplifier so that the cars regulator can do its job and keep the battery voltage constant; this is why the lights do not dim with a cap, as proven by many who use one.
Tony
BTW I believe someone owes me $5000
Old Apr 28, 2005
Prove it to richard clark. He, nor I never said they don't help dimming. That's the point you're missing. They are not a guranteed fix for dimming as evidenced by the people that get zero effect from adding a cap. They can help with dimmming, but they don't always work. The point is that they do not increase voltage readouts or put the voltage closer to 14.4 volts.
You people just do not seem to be understanding that fact. The point wasn't that they won't help dimming, because they can. The point was to disspell the myths about what caps do. Some of those myths include the following, among other things that are mythical and circulated on message boards all over the place:
"Caps increase voltage, providing support for the charging system"
"Caps improve bass response"
"Caps make your bass louder"
"Caps help voltage stay around a constant 14.4 volts"
Etc...
Reading and understanding is a basic concept. Obviously some people haven't mastered that.
I believe someone owes me, a taxpayer, some money for helping pay for the education that they obviously didn't get.
Old Apr 28, 2005
diskreet's Avatar
Etc...
My question is this: if he feels he needs to prove caps dont do anything for voltage, etc, yet will agree that they help with dimming in some cases, then i want the reasons they help with dimming. WHY do they help with dimming? Have anything to do with voltage? Please explain.
If he can "prove" caps dont help with <all his points> then give me scientific reason why they help with dimming. I would like to know, since that was conviently left out.
Good point on the subject of the author's resistance(ESR) complaining bullsh*t!
Please take this only as my opinion:
Seems like whoever wrote that is hellbent on proving caps do nothing. He tried to act like he is all-knowing, like alot of immature pre-teens on gaming forums, and did everything he could to bend the truth for his cause. Perfect example is complaining about the cap's resistance when it has one of the least resistances of anything besides most wires in the system.
Old Apr 28, 2005
diskreet's Avatar
Completly differend thing here:
Is it just me or is he just a moron for saying this. no where in the world did anyone I know of say a cap is efficient as STORING a charge. Its not made to hold huge charges. Its supposed to, in theory, hold a smaller charge and discharge very quickly. So this is 100% irrelivent? Once again "evidence", well actually stupid waste of typing, that is only stated to try to get people to see it his way.
I am not trying to say everything he said is wrong, but this guy is one big jackass. he has so much crap and slanted information spread between facts the whole thing just becomes one big blob of wasted text.
Old Apr 28, 2005
ncirom2003's Avatar
ask white_rabbit he seems to be very knowledgeable about this stuff
Old Apr 28, 2005
diskreet's Avatar
sorry for my fired posts but i got a little carried away. the guy just seems to be a ***** and doesn't realise that people notice how much he bends the truth, and how obvious it is
Old Apr 29, 2005
AlienX's Avatar
AlienX will become famous soon enough
i understand the posts, i dont exactly agree with it.
Caps are in parelle, yes thats why increasing the amount of them would decrease resistance, fine, its just that it already has a resistance lower then 99% of the whole system.
Caps are not made to STORE power, but to discharge and charge rapidly. Caps also have another purpose and thats to isolate noise. If you have ever looked or made any kind of electrical board you would notice that you put a cap as close as possible to the power source to reduce noice but this is another topic.
Lights dim due to a drop of voltage(power in general), if a cap doesn't help keep voltage constant why do your lights suddenly stop dimming ?
Caps will and have always been a topic of debate, I stand by mine and I do notice a differance. Yes the battery part is correct and our system is pretty much ran just by the alternator. Miketrain is also correct on this stand point where and amp will not use constant power but jumps around wanting it only at peek times. Ill continue this discussion later.. too tired right now. Good night ppl.. if anyone has anything intresting to say, go for it. But again, knowledge is power, so please post something that has some fact to it...
Old Apr 29, 2005
AlienX's Avatar
and popcorn, you have some explaining on your side also.. since you were for caps, now against them... maybe you should educate your self a little bit because just believing someone elses words..
this is a quote from you on the thread titled.
What advantage does a brand-name capacitor have?
"The single most important attribute is the capacitance value (expressed
in Farads). Put simply, more is better. Another important
consideration is to make sure the maximum voltage rating of the
capacitor safely exceeds the operating voltage of your vehicle's
electrical system. In addition, ESR and ESL values may be provided
with some capacitors to essentially indicate the amount of voltage drop
that occurs when a capacitor is delivering current. Smaller values are
better in this regard. " http://www.faqs.org/faqs/car-audio/part1/
Simply put, brand name isn't the issue, capacitance it.
Old Apr 30, 2005
miktrain's Avatar
A few more answers. Your staements in " "
“He even offers $5,000 for anyone that can disprove him, but the catch is you have to have factual scientific data to prove it.”
The lights do not dim... therefore; it makes sense that the voltage is not varying as much....
Is that enough ‘scientific data’?
"theorys"
From your spelling, grammar and harsh attack on those who dare to disagree with your post, it is easy to see that you are either very young or very uneducated. Who is it that requires education?
“At the end of this thread you should be the one that can explain to the world that according to ohms law it is impossible for these things to do any good”
According to scientific theory, a bumblebee cannot fly because its wings and body are wrongly proportioned.
“Suppose we have a resistor that is .017 ohms (seventeen milliohms). I think that is what you say the ESR of the giant caps is.”
You only “think” perhaps before explaining the world and universe to all you should find out the facts for yourself so that you can state the figure is…. BTW the figure is about right.
“The ones I have seen have measured higher but I will give you the benefit of the doubt.”
Please explain your method of measuring as it is easy to get a wrong reading. As you pertain to know all I thought I might gain something from your method.
“For the sake of theory only let’s say we have built the largest cap in the universe and it has billions and billions of Farads. Its plates are made of a newly discovered material we'll call unobtanium. This new material has no resistance therefore our super cap has an ESR of ZERO ohms. We then charge the capacitor to 14.2 volts. We then place a resistor with a value of .017 ohms in series with one of the terminals of this cap. The question is: If we place a load that draws 100 amps from this cap what will the resulting voltage be on the load side of the resistor? What will the voltage be on the cap side of the resistor? What about if we increase the load to 300 amps? What will the voltages be on each side of the resistor?”
Unless it is a very high wattage resistor, the load side will be 0 volts and the cap side will be about 14 volts as the resistor will no longer exist and there will be the stench of escaped smoke.
“But don’t forget about ESR as it is one of the important final building blocks in our search for truth about caps and we will come back to it.”
Having totally confused everyone with unnecessary rambling, we will use it to “prove how smart we are”
“But first, the homework. This is a “think about it question”. We have learned that a Joule is a watt second. A Yellow top battery is rated at 65 amp hours. This means it can provide 65 amps for an hour. The question is how many Joules does this represent? Since this is a thought question, it would really help if whoever answers would show us your math.”
Only in theory, if you draw 1 amp it will last about 65 hours but drawing 65 amps it will be lucky to last 30 minutes. “Please show your math” = I cannot do it but I will rip your answer to pieces to “prove how smart I am”
“In the actual real world the voltage of the battery would drop a little from its open circuit voltage of 12.8 volts with a 65 amp load. In the case of the yellow top its actual voltage at 65 amps is about 12.2v when fully charged.”
Try measuring the voltage of your car battery while cranking the engine it will be quite a lot lower than you think. Ohm’s law E = I x R or turned around E / I = R
12.8 / 65 = 0.19692307692307692307692307692308 (rounded 0.197) so the ESR as you like to keep quoting = 0.197 now if we draw 65 amps through that figure and use your method my calculator gives me the answer of 0 volts so now according to your theory a tiny cap is better than your 65 amp battery!
“Unfortunately 170 watts of power will be lost in heat in the ESR of the cap.”
If this were true, the heat generated would open the vent on the cap and you would have a lot of mess in your car, I have not heard about this problem so your theory must be suspect
“If you want to check me, go to Radio Shack and buy the following: Bulb # 272-1127, Socket # 272-360, and a nine volt alkaline battery. For the battery a Radio Shack is ok but a Duracell is better. Make sure it is fresh!!!!!
Wire the socket and connect it to the nine volt battery and record how long the bulb stays lit. Be prepared to wait for a couple hours. Charge a giant cap to 14.2 volts and do the same with it. Be prepared to wait about an hour. Charge a 1 or 1.5 Farad cap to 14.2 volts and do the same. This will take only a few minutes. Record the times and we will discuss the importance of this in our next lesson.”
This is because the internal resistance of the battery is much higher than the caps and delivers low current over a long time as opposed to the cap, which dumps everything near instantly.
Here is a test for you, put the 9 volt battery on your tongue… you get a small tingle and quite safe because of the internal resistance… try it with the cap IF YOU DARE! CAUTION I would not advise this it is dangerous
“Alternator regulators are usually temperature sensitive. As they get hotter they tend to fold back. For this reason we let the unit cool off between each test and closely monitored the case temp throughout the tests.”
Any proper test should be done at normal running temperatures, which is how the system is designed to be used.
“We played the system as loud as we could get it that seemed to produce no audible distortion.”
Using only your ears (which are probably already F**ked from loud music can you really say that there is no distortion? Try to use equipment it won't lie if set up properly
“Unfortunately, when this thread started I was unable to explain the concept, as it was obvious that many of the people posting responses just didn’t have a good grasp of the way things really work.”
I do not think you do either.
“Even with efficiencies in the range of 60% to 90% an audio system is capable of drawing hundreds or thousands of amps from the cars electrical system.”
Thousands of amps, which ones?
“The very nature of music rarely demands more than a duty cycle of 10% to 20% from a power standpoint. This means that the audio system is demanding short term, but repetitive peaks of current from the electrical system.”
Finally the truth, this is where the capacitor comes in it smoothes out those peaks as seen by less light dimming.
“This means that the battery will actually be a continuous load on the alternator and provides no power to the system.”
Take the battery out and see how long the alternator keeps working without a proper load.
“No doubt the cap could help out a hundred amp alternator with the addition of an extra 30 amps even though it might be for only a brief instant.”
This is all that is required … a brief instant to stop the lights dimming.
“It should be clear that if the voltage doesn’t drop the caps don’t do anything. The voltage MUST drop for them to start discharging.”
If it does not drop then it does not need to do anything. They also absorb the high peaks.
Tony
BTW someone owes me $5K
