AMP and Subs question
Old Jan 6, 2002
NukeSilo's Avatar
NukeSilo is an unknown quantity at this point
I have 2 rockford fosgate HE2 12" (400RMS, 800Peak) im thinking of getting A ROCKFORD FOSGATE AMP. i was wondering what model would i have to get so i would be running the 400 watss RMS into each sub. a little over 400 is ok just need a model. I dont understand somthing to, the subs run at 4 ohms each, how come all these amps run at 2 ohms, will it work with my subs?
Old Jan 6, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
The RF punch 800.2 runs exactly that and that is the amp i reccomend
Old Jan 7, 2002
CIVIC9782's Avatar
CIVIC9782 is an unknown quantity at this point
I had two he2 and they kicked azz. I would reccomend the 800a2 and running a 4 ohm load . That would be the best way to go. or get a smaller amp that is 2 ohm stable(mono) and bridge the two subs . either way will work good luck
Old Jan 8, 2002
mohawkboom's Avatar
the 800.2 runs 800Wrms 4ohm mono... or 200Wrms 4ohm x2 .. Not the right power ratios here. an MTX6500D would suit you perfect.. puts out around 800Wrms into a 2ohm load..if you want to stick with an RF amp.. get a Power BD500D.. puts out about 700Wrms.. and the differnce between say 500 and 800 watts.. is maybe 2 decibels..so the little less bit less power will most likely be unnoticable anyways. and the BD500.1 is a class D amp.. it's more efficiant and is lighter on your electrical system. I'd also highly reccomend a 1 Farad capacitor as well..(just for the slightly better bass responce during long sweeps) .5 farad cap would be good too..but spend the extra $25 and get a 1 farad..leaves you room for upgrades.
Cheers
Mohawk
Old Jan 8, 2002
LJ's Avatar
LJ
the HE2 has dual 4 ohm voice coils, with one single sub, you can either wire the coils in parallel and have a 2 ohm load, series 8 ohm load, or you could have an amp that is 200x2 @ 4ohms, but i don't reccomend that. so, if you have 2 HE2's, you could wire them both in parallel and wire them series to the amp, and get a 4 ohm mono load, OR with the 800.2 you could leave them in 2 ohm and run them one on each channel, because it runs 400x2 @ 2ohms. so there are your options for that amp. it is on sale at crutchfield, but i won't post the price
Old Jan 8, 2002
mohawkboom's Avatar
D'Oh.. my bad..thought they were 4ohm SVC subs.. Shows how well I keep track of RF products.. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers'
Mohawk
Old Jan 8, 2002
NukeSilo's Avatar
thanks alot for the input, it was very helpful. 1 question, the subs run on 4 ohms each, is it safe if they are ran at 2? also the amp that i mentioned., that would be the perfect one to run my 2 subs at 400 watts each correct? thanks again[IMG]i/expressions/beer_yum.gif[/IMG]
Old Jan 9, 2002
LJ's Avatar
LJ
yeah its safe for your subs to run at 2 ohms, email me and i will tell you how to wire them. subs LOVE running at 2 ohms, the bass is deeper, a lil louder, but a slight difference in clarity
Old Jan 9, 2002
LJ's Avatar
LJ
redcloud
25
Aug 12, 2015 01:23 PM
mrwhos
Aug 11, 2015 02:03 AM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
