how can I get my compustar...
Old Mar 9, 2005
*misslynn*'s Avatar
*misslynn* is an unknown quantity at this point
to stop chirping 3 times? I'm assuming someone tried something, but car's fine, now I just want to lock/arm it and make it stop chirping
Old Mar 9, 2005
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
If you find out let me know. Mine only does it sometimes. Wait you mean the remote chirps right. If you mean the car itself chirps, hold I+II until you hear a beep.
Old Mar 9, 2005
*misslynn*'s Avatar
nah, both chirp. and when it does, kinda looks like a glove or a piece of toast pulling on the window
Old Mar 9, 2005
HEBEGEBZ's Avatar
Not sure. Sometimes I get three extra chirps from my remote. Sounds a lot like the TV show "24" going off. I like it! As for how to make it stop or make it do it everytime I have no clue. What model do you have.
Old Mar 9, 2005
*misslynn*'s Avatar
blue remote, two way. can't remember the model number
Old Mar 9, 2005
paradoxblue's Avatar
haha that chirping three times means someone pissed withy our car. or hit it. or knocked it.. generally if it chirps an dlights an area u may want to check that part of the car
Old Mar 10, 2005
HEBEGEBZ's Avatar
Ithink she means just after you arm it the remote will beep three times
Old Mar 10, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I think she needs to read my descriptive thread titles thread! I don't have any idea about the alarm though, sorry.
Old Mar 10, 2005
OyD's Avatar
OyD
OyD is an unknown quantity at this point
3 chirps = door open
Old Mar 10, 2005
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
mine did this, what was wrong is a pin in one of the harnesses came out, cause I was messin around down by the brain. You should get it checked out.
Does the alarm register as being turned off after you disarm it? Or does your light continue to blink?
Old Mar 10, 2005
EternalBluePearl's Avatar
EternalBluePearl is an unknown quantity at this point
wait for few sec b4 u lock ur door
or ur might be on passive
and hes warning u dat hes locking ur door
Old Mar 10, 2005
*misslynn*'s Avatar
sorry, the descriptive thread came up after. will keep in mind. anyways, after some further investigating in daylight i found the problem. someone opened their door on mine, (area where the glove was flashing in my remote). guess that's what happens when you work in an office right beside an orthodontist. goddamn kids hopping outta vans
Old Mar 11, 2005
catalin's Avatar
catalin is an unknown quantity at this point
If you read your manual OR download one you'll find that the piece of toast is actually an indication that the hood pin that was installed under the hood is faulty. It's a very common problem... Talk to who installed it for you and have them fix it since it should be under warranty.
You will not be able to arm the alarm until you have that pin fixed.
FurBall
Jul 29, 2002 11:30 PM
