mono amp pushing 2 subs?
Old Mar 7, 2005
nick82006's Avatar
nick82006 is an unknown quantity at this point
Cool mono amp pushing 2 subs?
Is it possible to wire 2 subs to a single class D amp, if so what problems woudl u run into? thanks
Old Mar 7, 2005
SiG's Avatar
SiG
I think its possible
What problems were you thinking you'd encounter?
Old Mar 7, 2005
zachgeyer's Avatar
anything is possble
Old Mar 7, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
Yep your amp is allready bridged on the inside hence "mono amp": the speaker outputs are connected on the inside of the amp thats why you cant get a stereo signal out from it.The only thing you have to worry about is impedence or ohms. If your amp is an 2ohm mono amp then you can run two 4ohm or 4 8ohm subs in parralell.all the pos. to the pos. of your and all the neg. to the neg of the amp.If your amp is a 1ohm mono amp then 4 4ohm and 8 8ohm subs in parralell.
Old Mar 7, 2005
southwest713's Avatar
southwest713 is an unknown quantity at this point
yes, it is possible. but first you need to know what impedance the amp is stable at and the voice coil configuration on the subs. for example if u have 2 subs each being dual 8ohm voice coils u could wire those in parallel, then wire both subs in parallel to end up with a 2ohm load. in this case u would probably want something that could put out enough power at 2 ohms for both subs. if u wire at an impedance lower than what the amp is stable at, it might turn off a lot or u may even damage it because it wouldn't be stable. if u wire them at a higher impedance u will get less power but no damage to either the amp or drivers.
Old Mar 7, 2005
4Saris's Avatar
4Saris is an unknown quantity at this point
Yes, it's possible.
What kind of subs do you have? (Dual Voice Coal, Ohms for each coil)
What kind of amp do you have and is it 2 ohm stable?
Old Mar 7, 2005
Regularjoe's Avatar
Regularjoe is on a distinguished road
You can run as many subs as you want off any amp .... as long as the ohms and the wiring is correct.
What subs and amp exactly ... then we can go from there.
Old May 9, 2005
chicohonda02's Avatar
Since 2002 Baby!
Why Am Always So Confused With This Stuff. ****!
Old May 9, 2005
Regularjoe's Avatar
welcome to 2 months ago ....
Old May 9, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Thats why he's confused, Joe.
Old May 9, 2005
ncirom2003's Avatar
yes its possible in fact im doing this also
ive got a RF amp rated at 500 w x 1 at 2 ohms
im wiring my 2 12w3(v1) 4-ohms down to 1 ohms and so the amp should push out an estimated 650 watss x 1 at 1 ohms meaning each sub will get 325 watts.
Old May 10, 2005
CplJon's Avatar
Rape is no laughing matter--Unless your raping a clown!
CplJon will become famous soon enough
http://www.jlaudio.com/tutorials/wiring/index.html
I have 2 dual 2ohm subs with a mono--series/parallel will keep them at 2 ohms. Many different possibilities.
Old May 10, 2005
J187's Avatar
Depending on the regulation of the amp, you should be getting something closer to 1000 watts from dropping the impedence to ohm.
Is your amp rated at 1ohm??
Old May 10, 2005
ncirom2003's Avatar
well the amp is rated at 250 at 4 ohms and 500 at 2 ohms so i figured obvious math would mean 625 at 1 ohm but it will really bump it up to 1000???
the amp is not rated at 1 ohm anywhere on i asked a guy i know who is very smart with these things and said that it should be ok at 1 ohm cus he has delt with these amps alot when they were new (theyre from 95 lol but hardly used and FREE)
GolNat
Nov 27, 2018 03:32 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
redcloud
Sep 7, 2015 01:45 PM
