I'm a dumbass
I'm a dumbass
I changed my stock cd player for my aftermarket headunit, but what I forgot to do was take the cd out that was in there. Being the weather is below freezing I didn't want to go back out and redo my deck install just to plug the power back in to eject the CD. Long story short, if anyone needs to know how to take apart the stock cd player and get out their CD without power, I'm the man who can help you
you can use a 12volt power supply to eject the cd
or if you are into destroying things, you can open it up...
i've opened up several 7th gen stock decks before and i'd say it'll be fastest if you have a 12volt supply you can use....
12volts from computer powersupply is fine...the 12volt outputs are capable of outputing 10+ Amps
I had the same thing happen to me when i tried to replace my one aftermarket CD player with another. Needless to say, it didnt go so well for me. I took the Cd player apart and was never able to get it back together
GrayGhost
Nov 20, 2003 12:35 PM
R3DF0G
May 12, 2003 01:27 AM
