Opinions on Equipment
Old Feb 4, 2005
fasssstjapbike's Avatar
fasssstjapbike is an unknown quantity at this point
Hey guys, this is my first post but I've been viewing here for awhile and I need to know what you guys think of this system I'm setting up.
I'm going to be running:
Kenwood KDC-X879 Head Unit
ADS PH30.2 6 Channel Amp
Infiniti 6.5” Component Speakers for fronts
Soundstream Davinci 12” Sub (DV-12)
Tsunami 1.2 Farad Capacitor
I don’t know if I’m changing the rear speakers or leaving them stock, either way they will be powered off my deck. I’ll be using channels 1-4 for my fronts. I’m thinking of one channel for each mid and one for each tweeter and not even using the crossover that comes from Infiniti. Channels 5-6 on the amp I’ll use bridge for the sub. I’ll be running 4-gauge down the passenger side to the cap and amp, and running the rca’s down the middle. I’ll be building a custom 1.5 ft3 ported box for the sub. Check out the specs below and let me know what you think, I’ll be doing the install this weekend.
Specs
ADS PH30.2 Amp
• Watts/channel 4 ohm: 75x6
• Watts/channel 2 ohm: 110x4 + 150 x 2
• Watts/bridged 4 ohm: 220 x 2 + 300 x 1
• THD: 0.10%
• S/N Ratio: >90dB
• Bandwidth: 10-30kHz
• Damping factor: >150
• Frequency Response 25 Hz-1.4 KHz
• 320 Oz. Magnet
• 3" Voice Coil
• Sensitivity 87 dB
• 13mm XMAX
• 1000 Watts RMS
Old Feb 5, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
If you're powering them off the deck, keep the rears stock.
Old Feb 5, 2005
tripledoublegs's Avatar
Euro-Spec
are you sure you're able to bi-amp your front components with that amp? If not, you'll just end up frying the tweeters
Old Feb 5, 2005
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
dang ur going all over the place w/ ur brands huh
Old Feb 5, 2005
MegaHurtz's Avatar
x2, this guy stole my post
Old Feb 5, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
The rears actually work well for fill off the deck
Luluharp
Sep 27, 2015 11:56 AM
General DIY
Sep 25, 2015 08:02 PM
curaze
Sep 22, 2015 08:27 AM
bashea
Sep 15, 2015 04:59 AM
rayaan_wasty
Sep 14, 2015 02:00 PM
