LCD dash replacement
Old Mar 30, 2005
  #31
TheSmuggler's Avatar
Ok, quick question YS, what program did you use, and how are you getting the radio and what if I want satellite radio? lol
Old Mar 30, 2005
  #32
thekuai's Avatar
thekuai will become famous soon enoughthekuai will become famous soon enough
ys did u have to do any bondo fiberglass work to get ur screen to fit or u just screwed that in? i want to do an in dash and was gonna bondo a 7" lilliput in an ex dash....but if u dont need to bondo with the ex se dash ill go that route!
Old Mar 30, 2005
  #33
YS's Avatar
YS
YS is an unknown quantity at this point
TheSmuggler = I use Frodoplayer (www.frodoplayer.com) with my own custom skins. I'm using USB GFM Tuner and you could use XM radio, but i don't know how to set it up
thekuai = i don't modify anything on the EX SE dash, i just modify the LCD housing (cut it and bondo it) and then just screwed the lcd in. like i said on the previous post, if you mounted like that, you can not see anything at day time, so my next project is take out the lcd monitor and mounted different way (probably with somekind of hinge) so i can flip it back and front and i'm going to try to put a slim dvd-rom under the lcd
Old Mar 30, 2005
  #34
YS's Avatar
YS
from left to right
garage openers (my brother's and mine)
oem fog light
top: temporary disable my carputer
bottom: USB port (data transfer, charging pda/cell)
power plug
thesushiboy
Apr 12, 2015 02:54 AM
honda4life
Jan 8, 2002 12:06 PM
Foom
Dec 6, 2001 01:11 PM
CiViCPrAnInG2k1
Nov 27, 2001 12:07 PM
WhosYoDadday85
Nov 13, 2001 09:38 PM
