Alarm Problem
Old Jan 23, 2005
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
Alarm Problem
I just got my car back from body shop today ,and my alarm light is not working. My alarm work but my light don't lite up when i press unlock and lock key like the tail light bulbs and front signal bulbs dont flick or something. Need help what could be my problem?
Old Jan 23, 2005
streetglower's Avatar
your car is in the vallet mode. It will still lock and unlock, but the lights will not flash. You need to figure out how to get it back in the regular mode. Forgot what it is called. Usually if you unlock and lock the doors several times, it should go back.
Old Jan 23, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
valet mode only disable the alarm system but the parkin light will blink still.
check under the dash behind the fuse panel, thats where the installer might splice the parkin light to.
Old Jan 23, 2005
thanks.. My friends said it could be alarm fuse. Do alarm have fuse?
Old Jan 23, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
yea they often do, especialy if you have remote start.
civic1316
May 29, 2015 05:13 PM
Laurenhunter7
May 10, 2015 01:09 PM
pincookie1
May 4, 2015 12:22 PM
MamaBear2015
May 3, 2015 02:17 PM
Linda0818
Apr 23, 2015 11:30 AM
