Radio headunit HELP!
Old Dec 22, 2004
aoar's Avatar
aoar is an unknown quantity at this point
This may be the wrong forum, but it is the one with the most readers,
I'm trying to change my factory headunit on a 04 sedan, i've gotten both plastic pieces by the center console and the cigarette lighter out, i've taken out both screw's under it, but now i can't seem to push out the radio console. When i push on the bar, the whole console moves but it does not come out.
I read both DIY's and it says to remove the HVAC panel first? is there a step that i'm missing after removing the two screws? Am i supossed to just pry off the trim under the defrost, ac, air-recirculate buttons? Thanks for your help.
Old Dec 22, 2004
aoar's Avatar
are you suposed to pry the entire console? thats the idea that i'm getting from here..
http://www.ben-johnson.org/blog/archives/2003/07/37/
Old Dec 22, 2004
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
You gotta yank the whole assembly out. I have an 01, but I don't think they changed too much since then. If you have the pocket under the radio, grab that and pull straight out. The first time getting it out is a huge bitch, but you can do it. Just try not to get really pissed and break anything.
Old Dec 22, 2004
aoar's Avatar
lol that sounds fun. So you mean to stick my hand right on top of where the two screws were and pull really hard there? Is there any other method other than the brute force method? WHen i try now, the whole thing budges and shakes, but does not come out, are there actually clips behind the console as the link on top says? Thanks alott
Old Dec 22, 2004
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
looks good but here's a better pic of the cig lighter thing removed
Old Dec 22, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
I thought there was more than just two screws, I thought there were four you had to take out to remove it.
Old Dec 22, 2004
2K1Civic17"Gabe's Avatar
Mine doesnt even stay anymore. I lost like all but one clip. I can pull gently now, and it comes out. I think I need some new clips!
Old Dec 22, 2004
booba5185's Avatar
i got a better one, when i got in my accident in may, i got rearended and the whole console flew out and hit me
Old Dec 22, 2004
dma001's Avatar
dma001 is an unknown quantity at this point
I have an 01, and there are about 7-9 clips that hold the nosepiece in the dash. I used a butterknife and gently pried them up while pushing out from the back. It'll pop right out.
Old Dec 23, 2004
BassKadett's Avatar
Any luck yet?
Old Dec 23, 2004
runner1738's Avatar
does the diagram from cructhfield not explain everything ? http://www.7thgencivic.com/forums/sh...d.php?t=188060
Old Dec 23, 2004
Akutenshi's Avatar
The Rizing Sun
dammit those are some nice diagrams ^^
Old Dec 23, 2004
MegaHurtz's Avatar
Push harder
Check my DIY
Old Dec 23, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
thats what the bottom piece looks like (from the back so you can see where the clips are)
thats the hole... also so you can see where the clips are.. yer best bet is to just wrap a screwdriver in tape and gently pry it out
and while yer at it.. might as well start painting stuff..
Old Dec 23, 2004
runner1738's Avatar
just a queation, so when your installing the headunit, you just plug the harness into the connector it looks like then attache the free wires to the headunit is that right?
Old Dec 24, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
You connect the wiring harness you buy for the car to the wiring harness that comes with the radio. Then you plug one end of it into the cars radio harness and the other end into your radio.
Old Dec 24, 2004
againifall's Avatar
Go Team Venture!
unless you need another harness to connect yer car to the HU unit.. ive got like 30 miles of wire cramed in behind mine.. friggin sony pos
Old Dec 24, 2004
pon55's Avatar
Me too!
Old Dec 25, 2004
aoar's Avatar
Thanks alot guys, i didint know there were clips that held the whole piece in. we (my friend and i) used a butter knife to pry the whole thing out. Include the pic with the entire console out in the diy (versioin 2) so others could see that they're held in with clips.
Thanks for everyones help~!!
ricer_em2
May 11, 2016 08:09 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
