factory stereo to amp
Old Dec 19, 2004
mykicks007's Avatar
mykicks007 is an unknown quantity at this point
Does anyone know how i can keep my factory stereo and hook into an external amp (for woofers) ?? And if so, will sound quality be compromised ?
Thanks
Old Dec 19, 2004
2k3kansasEX's Avatar
Got the broccoli in my back pocket
2k3kansasEX is an unknown quantity at this point
everyone is going to say because they all love alpine! but ya you can you got hook up a thing not sure what its called rca something. i had one fro a while it sounded fine if you arent going for compition sound or anything.
Old Dec 19, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Many amps have "speaker level inputs" where you plug the spliced wires that go to your factory speakers. The sound quality is worse than using RCA w/ a high volt preout, but I don't know to what extent.
Old Dec 21, 2004
madmaddiel's Avatar
madmaddiel is an unknown quantity at this point
I had my factory HU into an 6 chan amp, but recently switched to an KENWOOD HU, huge diffrence, theres alot more settings to play with on the new HU, worth the little extra money for the new HU
Old Jan 13, 2005
sweetcivic03's Avatar
sweetcivic03 is an unknown quantity at this point
you need a high-low converter....sound would not be as good as an aftermarket head unit
Old Jan 14, 2005
Ed's Avatar
Ed
It's typically called a Line Level Convertor, shouldn't cost too much, but like said above, check to see if your amplifier accept speaker level inputs, then you'll be set. The sound quality will not be the best, but when you're just running subs, you probably won't notice a huge difference at all.
Ed
Old Jan 14, 2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
This is what I used to add a powered Bazooka sub. A Bazooka customer service rep recommended using this since is adjustable. He said it would have better sound quality, and louder, than using the high level inputs that are built-in. Installation was easy.
Old Jan 14, 2005
vicn77's Avatar
vicn77 is an unknown quantity at this point
easiest way is to use the line level convertor...most of them that you buy at bb or cc are adjustable....easier way to install it is to just tap them off the rear speakers since the amp is presumably going to be in the trunk area...
Mc7602
Sep 17, 2015 02:01 PM
Gsxtacy
Sep 12, 2015 01:09 AM
J-Fly
Sep 10, 2015 08:39 PM
redcloud
Sep 7, 2015 01:45 PM
