How and where to mount the XM antenna?
Old Dec 13, 2004
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
I have 2003 4door honda civc. I just got the xm today and dont know where to mount the xm antenna? please help.
Old Dec 13, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
start by mounting your two threads into one :P
Old Dec 13, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
I think someone mounted an xm antenna inside the center brake light housing
Old Dec 13, 2004
i want to mount is on the trunk or top of the car by the back glass.
Old Dec 13, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
mine is in the middle of the trunk lid...works great, or you can do on the roof.
Old Dec 13, 2004
then I guess your answering your own question
Old Dec 13, 2004
still need to know how to get the wire out there. "READ" THE topic.
Old Dec 14, 2004
4Saris's Avatar
4Saris is an unknown quantity at this point
Did it not come with instructions? All I did was follow the ones that came with my sirius antenna. Basically you tuck the wire under the flexible rubber that goes around the rear window. You can drill a hole and fill it with silicone or tuck it under the rubber insulation that surrounds the trunk. I did the latter of the two, and have no problems. It's really easy.
Old Dec 14, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
mount on roof. run wire down between your rear window and the sheetmetal, there is a very small space between the two perfect for this. run it down into your trunk, then your good to go.
Old Dec 14, 2004
So i should start running it from the side then pull it to the middle? becasue only space little space i see is on the side
Old Dec 14, 2004
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if you look at the gasket on the rear window, you can lift it up and place the antenna cable under it, then when you let go of the gasket, you cant tell the wire is under there
Old Dec 14, 2004
ok thanx. i am gettting somewhere now lol. so i can start running the wire from the side and the pull it to the middle. lift the gasket and hide the wire underneath it right?
Old Dec 14, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
i put mine on my back dash...never had any problems with it. never cut out or anything.
Old Dec 14, 2004
i cant put mine on the back dash. first, when the system hits i doubt it can handle it and second i have 2 layers of limo tints on the back glass.
Old Dec 14, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
i bought the sat. radio antena from the honda accord because it is color matched. (SSM) the only hard part is that i had to drill a hole in the trunk lid to mount it. it looks so much better than the flat black ones though.
mgrantaz
General
May 2, 2022 05:40 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
twd000
Oct 4, 2015 12:52 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
