I need some clarity
Old Nov 5, 2004
fonto's Avatar
The LA Clipper
I need some clarity
He guys, I just wanted to check on something because I forgot the answer, and i was not able to find a definative answer by searching. For a 2002, do I need to connect the power antenna lead to get good reception? I assume it is the green/yellow wire?
Thx
Old Nov 5, 2004
fonto's Avatar
The LA Clipper
bump bump bump
Old Nov 5, 2004
MegaHurtz's Avatar
Yes you do.
With my old deck, I do not remember having a wire for the power antenna hookup on the harness... if the antenna did indeed require power, it didn't have it. I got horrible reception.
With my new deck, there WAS a power antenna wire, and I hooked it up, now I get great reception
Old Nov 5, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Yeah, some other dude in here not too long ago said he couldn't even hear anything on his AM.
Old Nov 5, 2004
fonto's Avatar
The LA Clipper
So is it the green and yellow on the factory wiring??
Old Nov 5, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
yellow with green stripe
Old Nov 5, 2004
fonto's Avatar
The LA Clipper
Thanks Rick...I got it right
phris
Aug 22, 2014 03:45 PM
novice121
Jul 4, 2014 05:23 PM
richardcwc
May 13, 2013 05:44 PM
Quiksilver09
Apr 13, 2005 06:43 PM
skivic
Jul 8, 2003 08:35 PM
