Post your EQ settings
Old Oct 24, 2004
IronFist's Avatar
List your deck and your EQ settings:
Pioneer Premier DEH-p860mp
I forgot the frequencies, so this is from lowest to highest:
+6
+5
+4
+3
+2
+1
+2
+2
+3
+4
+5
BBE is on but set to 0.
All slopes set to 100Hz with -6db/Oct. Sub is at +3. On the amp the gain is at maybe 25% and bass boost is at 0. I have an amp volume **** that I can use to fine tune the volume.
For 99% of all types of music I've listened to, this setup sounds absolutely perfect. Every once in a while I have to use the amp's remote bass gain **** to turn it down a little if it's really bass heavy music, but other than that it's fine.
Strangely enough, many of the other settings I tried made it sound like it was obviously running through an EQ and didn't have very good SQ. Even when I set it to "flat" it doesn't sound balanced.
Ok, post your EQ settings.
Old Oct 24, 2004
LudlamTheory's Avatar
i boogie for the raindrops
sir, eq settings are things that are not the same for two people. theyre dependant on type of speaker, how theyre installed, whether or not youve sound deadened, how many speakers, and even factors such as how you sit in the car and how loud you listen to it, and most importantly, how YOU like your music to sound...
Old Oct 24, 2004
IronFist's Avatar
Yup. But I thought a thread like this might give some other people some ideas in case they weren't happy with their EQ settings.
Old Oct 24, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Alpine 7897
EQ settings = Defeated
Alpine 9833 (soon to be installed)
EQ Settings = Defeated
Old Oct 24, 2004
IronFist's Avatar
Defeated means it doesn't use any EQ, right? So it's like flat pretty much?
Old Oct 24, 2004
Pioneer premier 940mp amped speakers single sub all infinity reference with tweeters and dynamat all over.
Fade front +4
Sub 100Hz level +2
HPF/LPF 80Hz both
SFC, BBE TA = OFF
EQ 1, 2, 1, 2, 1, 0, -1, -1, 0, 1, 3, 0, 1
Old Oct 24, 2004
J187's Avatar
It means that what comes out of my headunit is pure, unmolested. My amps handle crossing the freqs. Usually, good amps have more reliable xovers than head units. some use xovers from the head unit and xovers from the amps. Some shutoff the xover settings on the amps and hu and use aftermarket xvoers like audiocontrol or PPI. I personally stick to the KISS model and just use my JL Amps xovers which are excellent.
Old Oct 24, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
4K -4db
Old Oct 24, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Read my profile for what I have, I dont feel like typing it
Sub Amp LP 100hz 24dB slope
Q 2
Center 45hz
Boost +10
Subsonic 15hz
High amp crossover on full range
HU LP varies according to what im listening to, anywhere from 31.5 hz with a 24dB slope to 65hz with a 6dB slope. I also adjust the attenuation according to what im listening to.
My speakers I adjust the HP on according to what im listening to as well, all the way down to 45hz (god I love QSDs) or up to 80ish. I dont attenuate my fronts, and I keep the slope at 12 most of the time.
I dont remember all my EQ settings...there are too many bands to remember off the top of my head, and I have two sets of settings; one for CD and one for XM.
Old Oct 24, 2004
brash's Avatar
brash is an unknown quantity at this point
-1 treble because my speakers are awfully trebly. Flat otherwise, except that occassionally my passenger side door rattles because of the bass (I need to fix that with fatmat-type stuff), so I turn down the bass if I am dying to listen to something that has too much of the right frequency to cause those rattles.
But as Ludlam said, EQ settings depend on the setup (except, of course, for those types of folks that boost their bass up all the way because it is cool to have loud bass). So I don't really see the point of this thread...
Old Oct 25, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
this thread is cool. some people may was to just referr to it for different settings like ironfist said. i probably have the most bizarre eq settings. i don't know them off the top of my head so i'll post them tomorrow
Old Oct 25, 2004
mos_skeeto's Avatar
mos_skeeto is an unknown quantity at this point
I have a Pioneer 5500mp.. Only 3 eq settings so I set it on default for powerful : 4-2-4... I have the sub on +1 and a HighPassFilter of 80 on my speakers so they dont blow when I turn it up.
Old Oct 25, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Pioneer Premier 740
Bass -1
Mid +/-0
High +1
HPF 80
Sla +1
Sub -2
bass (there's 2 settings for this, I forget the exact titles it has) 80khz+1
treble (again 2 for this) 180 khz +/-0
I forget the rest of the diff settings.
can't remember my amp settings right now.
Old Oct 25, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Pioneer 7400MP
EQ: Flat
Bass: 0
Treble: 0
Sub: 0
HPF: 80Hz
LPF: 50Hz
Old Oct 26, 2004
HondaSales's Avatar
pioneer dex-p9/deq-p9
20hz = 0
25hz = 0
31.5hz = 0
40hz = 0
50hz = 0
63hz = 0
80hz = 8.5
100hz = 11.0
125hz = 7.5
160hz = 5.5
200hz = 1.5
250hz = 0
315hz = -1.5
400hz = -3.5
500hz = -2.0
630hz = 0
800hz = 0.5
1khz = -1.0
1.25khz = -1.0
1.6khz = -1.0
2khz = 3.5
2.5khz = 2.5
3.15khz = -1.5
4khz = -2.0
5khz = -4.0
6.3khz = -5.5
8khz = -6.0
10khz = -1.0
12.5khz = -1.0
16khz = 1.0
20khz = 1.5
Old Oct 26, 2004
damn sir, you should look into better midbass drivers
Old Oct 26, 2004
HondaSales's Avatar
????? ummmm, i don't think so. thanks anyway.
Old Oct 26, 2004
MegaHurtz's Avatar
yeah that is a lot of boost
Old Oct 26, 2004
HondaSales's Avatar
i'm more than willing to go head to head with you with an official iasca judge (for sound quality)
Old Oct 26, 2004
J187's Avatar
Don't you guys both (Ludlam and HondaSales) have Utopia 3 ways?
Old Oct 26, 2004
HondaSales's Avatar
no, i just have two-ways'...
Old Oct 27, 2004
head to head?
man i wasnt putting you down
are your kicks sealed?
that may be your issue. thats some serious boost in the midbass region. im not all that familiar with the 6w driver from the 165w set, only the 6w1 from my 165w3 set
Old Oct 27, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
If he's talking sound quality then yea boosting midbass may "sound" bad but be the flattest response. Have you guys heard some SQ vehicles. Some really sound like crap to me.
Old Oct 28, 2004
HondaSales's Avatar
head to head?
i know you weren't putting me down, i was just messin around with you. no, my kicks aren't sealed but i know that everything was tuned properly. i've had the system for about two years and still can't get over the sound it produces. those focals are simply amazing!
