so i wanna run 2 amps...
Old Oct 9, 2004
jttegx's Avatar
OMNES AD UNUM
im a little confused and hopefully some of you audio junkies can help me out. heres my future set-up
2 (two) audiobahn mono-amps a8000t
2 (two) Kicker L7 15" subs (2ohm models)
2 (two) "2 fared" capacitors (one to each amp/sub)
now if i wanted to hook up 2 amps, would that mean i would need 2 power wires? meaning, theirs gonna be 2 terminals and power wires connected to my battery located under the hood and all the way to the trunk?
im trying to run one amp for one sub.
any info would be helpful,
thanks
Old Oct 9, 2004
MegaHurtz's Avatar
No you would need 1 large power wire from your battery to your trunk, going into a distro block that would have 2 equal size or smaller wires coming out of it, although you would be better to use a larger power wire for the main run due to the amount of current that will be carried through the wire.
Also, why 2 amps? You are better off saving yourself some money by just using one.
If you are just looking for "a lot of bass", try thinking of how much you actually need. 1600 watts and 2 L7 15's is a hell of a lot of power, more than you would really ever use. Even 1000 watts like I run in my car is a good amount of power, and with 2 10's it will blur your vision without a problem.
Not trying to second guess you or change your mind, but just suggesting that you consider what goal you actually hope to achieve with your system before you go out and spend the money. Worry about the details sooner than later
Old Oct 9, 2004
jttegx's Avatar
OMNES AD UNUM
the reason why i decided to go with the 2 amp route is because i already have one of those audiobahn amps. someone is giving me a sweet deal for the 2 kickers for $350 + installing my amp/subs/cap. so i thought purchasing another same amp would be my best choice as for money wise. as for so much bass, i ran 800rms watts in my car before and it didn't seem enough for me. i wanted something that would vibrate outside the car, be heard the next block down and other disturbing sorts of things =)
btw, thanks for the info
Old Oct 9, 2004
MegaHurtz's Avatar
Well if the price is right go for it.
Things other than the equipment to consider are the parts needed for installation. The wire you will need will need to be at least 1/0 wire which can be quite pricy. I would DEFINITELY DEFINITELY DEFINITELY upgrade your battery in this case to a high output one such as an Exide Orbital Extreme Cycle Duty 34XCD. If you have the money, also spring for a good quality high output alternator such as one from Iraggi. I would recommend the use of high quality RCA cables and a line driver to give your amps the proper signal and keep the gain down. Spring for the best connectors that you can afford (copper works very well) and make sure the connections are crimped AND soldered.
1600w is by no means a small amount of power and you gotta make sure everything is up to par.
Also make sure to sign up for a membership to IASCA or dB Drag Racing and start competing in the SPL circuit once it's all installed
Old Oct 9, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Why do you need 2 2 farad caps? Why not just one cap (if any) before the distro block. And daisy-chain the RCAs if they have outs.
Old Oct 10, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
holy ****...thats like 1600RMS WATTS!!!!!
Old Oct 10, 2004
MegaHurtz's Avatar
yes it is
Old Oct 10, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
1600 isnt that much...I ran 1500 on the stock battery for 2 years before it died.
Old Oct 10, 2004
takumi's Avatar
takumi is on a distinguished road
WTF? I was pulling 300W from the stock battery and it would die on me every few days
Old Oct 10, 2004
Ed's Avatar
Ed
I don't think your battery died like his died. Yours just got drained.. sounds more like your battery wasn't charging or something was eating power when teh car was off.
Old Oct 10, 2004
J187's Avatar
And it depends on how old the battery was to begin with.
Old Oct 10, 2004
alex053's Avatar
to run two amps on two subs you will need a high quality mulit meter and a test disc. put in the disc and start playing around 65hz.....now monitor the AC output of each amp and adjust the gain untill they both match...now turn it up and do the same thing. if you dont gain match the phasing will be off and it will sound like butt.
Old May 18, 2005
mr_fobster's Avatar
welp sorry you guys for bringing this thread back to life...but just recently i got a free amp from a friend. and right now my current amp is a PG Xenon 400.1 and it runs alright with my 2 audiobanh 12s(thanks jttegx for the great deal) and well im only putting 200 watt rms thorugh both subs. and the miracle of this amp that i got from a friend is that its the same one i have currently. so instead of me buying a 800 rms class d amp i was wondering would i have to go through all these things that jttegx is gonna have to do to run just 800watt rms though my car? cuz wat im thinking is hooking up one 400watt rms amp to one sub each, and then getting a optima yellow top or red top batt (just in case i get dimming) and soon to dynamat my car. but i have a feeling there is more to it than just hooking up these 2 subs to the batt and such.
because also i forgot to mention that i have a kicker 200.4 amp hooked up to my components and i am gonna get a new clarion deck (new=clarion dxz845mc old/current=clarion dxz545mp) so that i can have more preouts. so wat else would i need to take into consideration when installing 2 sub amps? thanks for helping out a semi-noob to ICE!
and boy im glad i searched this before posting a new thread...thanks for your help in advance
Old May 19, 2005
jttegx's Avatar
OMNES AD UNUM
you can run both amps to each sub by using a distrobution block. a disto block ( http://www.cardomain.com/shoptype/Distribution+Blocks ) splits your power wire into 2 seperate wires so it can feed both amps using one main power wire source. think of it as a "T"
since the 2 amps that you plan to run with the 2 subs are the same, you can easily match the specs *level, bass boost, LPF, etc*. so you basically need a distro. block to have each amp power each sub. 1 for 1.
and batteries dont prevent dimming. a cap would help but i dont believe in caps anymore after lots of researching. with the money spent for a new battery, IMO i would invest it into a higher output alternator than the super small 70amp OEM one in our civics.
Old May 19, 2005
mr_fobster's Avatar
so...getting a higher output alternator would be alot better than getting a new batt to replace the stock one??....man so many questions welll jttegx i think i might just talk to you online about this one....thanks for the help.
Edwin__em1
Jun 13, 2015 11:57 AM
ClutchMasterOG
May 31, 2015 03:25 AM
boostedboxer
May 25, 2015 10:05 AM
Caudill2011
May 2, 2015 12:04 PM
brill
Nov 12, 2001 07:29 PM
