What is defeat?
Old Oct 1, 2004
IronFist's Avatar
What is defeat?
I've seen that some head units have something called "defeat." What is this?
Old Oct 1, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
When interrupting external devices to this unit, turning
DEFEAT ON will bypass BASS, TREBLE and MX for the
external interrupt.
- Taken from alpines manual for the cda-7998 Head unit
Old Oct 1, 2004
Rufus's Avatar
It will sound like **** unless you have an external crossover/eq
Old Oct 1, 2004
MegaHurtz's Avatar
Amplifeir defeat maybe? turns off the amps?
Old Oct 1, 2004
LudlamTheory's Avatar
i boogie for the raindrops
they got it right, its defeating the internal processing, just a pure signal from the cd player gets sent out
Old Oct 2, 2004
IronFist's Avatar
So it makes it like there's no head unit controlled effects or anything at all when it's on, right?
Old Oct 2, 2004
MegaHurtz's Avatar
Flat then..
Old Oct 2, 2004
Rufus's Avatar
you got it.
