How high is 125Hz?
Old Sep 29, 2004
IronFist's Avatar
How high is 125Hz?
So the Pioneers I'm looking at have the sub crossover at 50, 80, or 125Hz. I'm worried that this isn't high enough. I saw an Alpine that would allow the crossover to go all the way up to 200Hz. Right now I'm using the stock deck so there is no crossover. I just don't want to spend a lot of money on a deck and then end up having the top notes of the bass line get cut off or something.
Anyway, is there a website or .mp3 or something that has different tones labled by frequency?
Old Sep 29, 2004
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
I'm guessing you are looking at head units with a built in x-over? The sub x-over is a lowpass filter, meaning it will send frequencies of 125 hz and below to the sub amp. Typically a good x-over point to start with would be around 90-100. This can vary based on speaker size, sub size, any number of things. 200 is way too high to set a low-pass for the sub. At that point you may even hear vocals out of the sub, not good. What are you using for the sub amp? A decent amp will have built-in variable x-overs that can be set at 40-200 hz depending on the system. I'll stop there, short answer, yes 200 is too high, 125 may even be too high. Alpine or Pioneer you'll be happy for sure.
Old Sep 29, 2004
Highest mine goes is 125Hz, and that's what I use. After that, sub response in car drops off dramatically.
Old Sep 29, 2004
zen_master's Avatar
80Hz is the best..
hmm...
i set my LPF to accept stuffs below 80hz...
and the HPF for front speakers to accept stuffs above 80Hz..
Old Sep 29, 2004
Actually, the drop-off happens around 80Hz, at least for my sub.
Old Sep 29, 2004
baggedblue02's Avatar
baggedblue02 will become famous soon enoughbaggedblue02 will become famous soon enough
Anytime someone starts getting high freq in the subs it starts to sound awful. If your cd player has an amp mute to cut the sound off, except sound going to the external amp and you have a much higher freq you'll see that voices start to come through and distorts when the bass should be hitting.
Old Sep 29, 2004
fonto's Avatar
The LA Clipper
If your front speakers can play low, there should be no need to cross you subs higher then 120hrtz...IMO
Old Sep 29, 2004
zen_master's Avatar
definitely don't expect that ur stock speakers will do that..
that's why i won't let any lower freq to go to my stock speakers...lol
Old Sep 29, 2004
IronFist's Avatar
My front speakers can't play low. They are Pioneers. They have even less bass than stock. My rear speakers are stock.
Old Sep 29, 2004
Rufus's Avatar
My kick panels do.
Old Sep 29, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
A couple of years ago this dude from work asked me to check out his system and tell him why his bass dind't sound good. Ok. So I get in his car and he turns it on and immediately I was like, "whoa! your rear speakers sound awful!" He was like, "dude, I don't have rears" . . . it was his subs LPFed at like 225!
Old Sep 29, 2004
MassMayhem's Avatar
Thats great. I had a roommate like that once. Had a Tacoma, no rears, JL Stealthbox crossed at 200. He tells me the midbass sounds "fuzzy". Well, yeah, cuz you are playing it through a 10" sub!
BTW, GO SOX!
Old Sep 29, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
I have a pioneer deck, and my LPF is set at 80HZ. 120HZ sounds ok too, but I prefer 80 HZ.
Old Sep 29, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
I got a JL amp and sub and I set the LP for the sub at 100
Old Sep 29, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
You guys LP your subs so high...mine is at 60 with a 24db slope. Speakers are HP at 90 with a 12db slope.
Old Sep 29, 2004
Why not tho if the sub can play those frequencies? My speakers don't play bass very loud anyway, so might as well use the sub for that.
Old Sep 29, 2004
Ed's Avatar
Ed
I low pass at 80 hz, I figure that's around where sound becomes directional, and nothing worse than having half your music coming form behind you.
what do you guys have you HPF set at? same freq? overlap?
Mystic, don't you potential have a gap at about 70 hz?
Old Sep 29, 2004
IronFist's Avatar
What plays your 61-89Hz frequencies then?
Old Sep 30, 2004
Mystic3030's Avatar
No audible gap because of the db slope. Remember, its not a direct cutoff, it just fades out.
Old Sep 30, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
My deck only has the options for 50Hz/80Hz/125Hz. I have it at 50Hz because 80Hz just makes it way too boomy. I'd love to try 60Hz or 65Hz though. My next deck will have adjustable controls. I just can't justify getting a new deck just for that. I'd have to step up to the Pioneer 9k series for that option.
Old Sep 30, 2004
b20vtec.com's Avatar
~Creatine Serum is good for j00~
b20vtec.com is just really niceb20vtec.com is just really niceb20vtec.com is just really niceb20vtec.com is just really nice
You want your sub freq between 50-80hz on your deck.. anything above that is way too boomy and annoying with no low freq extention. Just remember this quote "So low it HERTZ"
Old Sep 30, 2004
J187's Avatar
Anything above 80hz is too boomy?
Old Sep 30, 2004
IronFist's Avatar
Ok so right now I have my amp "frequency" **** set all the way up, which I think is 300Hz. (it might be 80Hz, as the documentation is not clear).
Right now it sounds awesome. I'm afraid if I get a head unit that limits it to 125Hz that I will be missing all the mid bass. My speakers don't do much mid bass so I have to have the sub play it. I turned down the frequency **** and it sounded more boomy and less musical. The midbass was gone. But my amp doesn't have the frequencies written around the **** so I don't know where it is.
So that's what I'm afraid of; the head unit limiting the sub frequencies to 125Hz and me losing my midbass.
What do you think?
Old Oct 1, 2004
My sub sounds just fine at <125Hz. The speakers are set to 80Hz, and they don't play hardly any mid bass. The sub can't reproduce higher frequencies as well inside the car. Look at the pic I posted, and stop worrying. It's actually damaging to the sub to play higher frequencies.
Old Oct 1, 2004
LudlamTheory's Avatar
i boogie for the raindrops
mine are down at 55-60, all speaker dependant
Old Oct 1, 2004
Very true. It's gonna be different for every setup. You just gotta see what sounds good to you and play with settings.
Old Oct 1, 2004
IronFist's Avatar
Dude I'm telling you mine sounds awesome when I turn the frequency up and it sounds shitty when I limit the frequency range.
However, because you are gearbox I will take your word for it. Isn't that pic you posted for YOUR sub tho? Afterall, you did say Actually, the drop-off happens around 80Hz, at least for my sub. I tried to find the specs for mine but I couldn't. All I know is the frequency range goes up to 1,000Hz.
I'm still a little worried about the 125-300Hz frequencies tho if I get that Pioneer deck.
Right now I'm more concerned with getting my fvcking remote bass control from Circuit City (see other thread).
Old Oct 1, 2004
If it sounds better at higher frequency, then you're gonna have to find a deck that goes higher than 125Hz. It's all personal taste. My pioneer is one of the best decks they make and still doesn't allow you to go any higher than 125Hz. Try to find your own sub specs.
Old Oct 1, 2004
IronFist's Avatar
Here's an interesting article on subwoofer crossovers, altho it's for home theater systems.
Old Oct 2, 2004
IronFist's Avatar
Hi I'm dumb, I just looked at the DEH-8600 again today and the highest crossover point for the sub is 200Hz. Much better than 125Hz, even tho everyone assures me I won't need to go any higher than that. So if I remember correctly it was 50, 80, 100, 125, 160, 200Hz, or something like that.
MamaBear2015
49
Sep 29, 2015 01:12 PM
JMKendrick
Sep 16, 2015 06:17 PM
JJ291
Sep 2, 2015 11:49 PM
silentz
Jul 9, 2015 08:16 PM
