Remote Wire Powering a LED....
Old Aug 13, 2004
  #31
MegaHurtz's Avatar
Originally Posted by turboslug
rules are meant to be broken :P...just be sure you know exactly what will happen if you break the rules...also, never dive into it blindly and dont try to push things beyond what they are capable.
if everyone followed the rules and stuck to the manufacturer's intended use, i'm sure no one would be modding their cars...no one would lower their car, no one would install lcd's into their seats..etc...
True true, it's just an area you've gotta be careful with I guess
Old Aug 13, 2004
  #32
MegaHurtz's Avatar
I've heard about that 42v stuff before too, but I didn't think they were going to do it because of problems with stuff like the rear defrosters which would cause your glass to break and stuff..
I hope they don't go that way, a whole new industry worth of car audio will have to be created.. and when they do you can be damn sure it won't be cheap
Old Aug 13, 2004
  #33
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
it will be much better for car audio...it will allow for much simpler power supply designs. the amp portions will still be pretty much the same. it'll make car audio cheaper to design and produce.
Old Aug 14, 2004
  #34
MegaHurtz's Avatar
But i would imagine that when they first come out like everything else, they would be expensive and then the prices would eventually go down
Cheaper in the long run ya probably, but at the start it'll probably be like any new technology, expensive as hell at first and progressively cheaper as time goes by
Old Aug 14, 2004
  #35
turboslug's Avatar
Super Hoser
i dont think it would be more expensive, maybe the same price at first, then gradually getting cheaper...
it wont be new technology...nothing new will have to be discovered(but i'm sure there's lots more they can discover to make things evey better)...they just have to implement the changes to their designs to adapt it for the different voltage
damn, i can imagine much more powerful headunits for the price of cheap ones..haha...all they really have to do is use a different amp chip that operates on a higher voltage(cheap), and use a different voltage regulator to step down the voltage for the other components inside...
Old Aug 14, 2004
  #36
slammedcivic85's Avatar
Member
slammedcivic85 is an unknown quantity at this point
Verified, but don't.... that's not what remote is meant for
Use your trunk light power wire to power this neon
Yea using your trunk light to power the wire wont hurt anything thats how i did my trunk only thing is the light will only come on when you open your trunk but why would u want it on any other time anyway
Old Aug 14, 2004
  #37
alex053's Avatar
use the remote wire to power a relay. all problems solved. hook up as much as you want.
Old Aug 14, 2004
  #38
MegaHurtz's Avatar
^^ That's what I would do, that's the proper way of wiring things
Old Aug 17, 2004
  #39
Benzboy429's Avatar
Benzboy429 is an unknown quantity at this point
leds are cool lol
Old Aug 17, 2004
  #40
MegaHurtz's Avatar
yep, that they are
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
MamaBear2015
May 3, 2015 02:17 PM
Dmitri
123
Oct 13, 2005 08:01 PM
clockwerx
Dec 13, 2001 12:39 PM
