False FG floor w/subs and amps
Old Jul 30, 2004
blackcivic28's Avatar
blackcivic28 is an unknown quantity at this point
Would it be possible with the spare tire removed, to create a false fiberglass floor that has two amps and one or two subs (whatever size that can fit) with the sub box going downwards so that the trunk space would remain the same and still have subs and amps (1 amp for subs, 1 amp for speakers). Thanks for the input and help in advance. I think this would be an awesome diy project that could command major respect and be very practical.
Old Jul 30, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
yup!
Old Jul 30, 2004
meseetree's Avatar
meseetree is on a distinguished road
it's sounds veryu possible
Old Jul 30, 2004
AlpineCivic's Avatar
It has been done so Yes it is possible.
Old Aug 1, 2004
ELaudio's Avatar
ELaudio is an unknown quantity at this point
Anything is possible with SKILL and FIBERGLASS. I've seen some crazy **** done at car shows. If you've never worked with fiberglass and resin, I highly recommend doing A LOT of research on technique. Or go to a pro-audio shop and have them do some of the harder parts for you.
Odds are, based on what you want, you're going to need to build up a "hump" for all that to fit into it. What you could do is build a traditional MDF speaker box and then make a frame out of cloth or chicken wire around/on top of it, and make openings for your amps. This will be a very tricky install, but it is do-able.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
