RaDAR DETECTOR PLACEMENT.....IDEAS...
Old Jul 18, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
I've decided, after one speeding ticket, I'm buying a radar detector now. I've been doing my homework, and since I live in VA, which uses the VG-2 radar detector-detector extensively, my choice was between the Passport 8500 and the Valentine One. The Valentine One has better features and I can still afford it, so I think I'm going with that.
Anyway, the reason for this post is; I need to figure out where to mount it. I think I'm going to buy the external display adapter, which means I have the display wherever I want to put it (planning on corner of A-pillar and dash). So, now that it doesn't need to be where I can see it, where should I put the main unit? I was thinking of making a fiberglass shell that looks like a gauge cluster to go ontop of the dash that has holed for the antennas or something like that. Whatd'ya think? Any ideas are welcomed. Remember, I do NOT need to see it. Actually, the point is for it to be as hard to see as possible.
Old Jul 18, 2004
Drnknmnky13's Avatar
How long is the cable? In the grill might be a good idea. Or really high so it's at the top of the windshield.
Old Jul 18, 2004
jwalker87's Avatar
Bodacious Member
I don't think the grill would work. Then, the rear radar sensor would be completely useless. Also, I don't think the housing is meant for it to be placed outside (waterproofing, etc...). I wish I could do that, but I don't think it would end well. I was thinking of either putting it, like you said, as high as possible, or on the dash, somehow concealed. The problem with high-up (the better option for sensativity) is: how do I hide it? I can make the cables longer; that's no concern.
Old Jul 18, 2004
MegaHurtz's Avatar
Cut out your headliner and have just a little bit of it poking out. Nobody will be the wiser
Old Jul 19, 2004
huggy_d1's Avatar
huggy_d1 is an unknown quantity at this point
Arrow Remote Radar Detector 2001 Civic LX
I've personally seen good success at using a unit similar in design to the Bel Remote Radar Detector. The main radar remote fits right under the front bumper where license plates go (for states that use them) so that the little unit is flush with the plate. The remote laser detector fits nicely on the windshield right there at the rear view mirror mount with wiring snaked around front headliner molding around to left pillar molding, and down under dash to the little spot to the left of the DC outlet between the console and dash.
The flat area just to the left of the DC outlet and in front of the drink holder recesses can be dremeled out in less than an hour, with the 12V feeding the DC outlet easily tapped into for power to feed the unit.
It looks completely unobtrusive in this location, even for routine traffic stops is undetectable.
I'd post pics, but, alas, even though I only use it on trips outside my state, it's not legal to have one in my state, so you'll have to use your imagination.
Old Jul 19, 2004
jwalker87's Avatar
Bodacious Member
the bumper idea sounds good, but that would ruin the rear detection. I was reading on the v1 site that, on motorcycles, you can put it inside of a fiberglass fairing unaffected. So, I was thinking; either make a small fiberglass bubble on my dash (with a fake faceplate so it looks like a CD player), or do some fiberglass enclosure attached to the roof. Where would I put it if I cut out a bit of the headliner?
Old Jul 19, 2004
huggy_d1's Avatar
Rear detection is only minimally affected with the main receiver in the front... plus the unit I sent the link on comes with remote front and rear laser detector units. The key to radar is REFLECTION of the signal from behind. In hilly and other areas not wide open there is plenty of bouncing signals to pick up on even if they are behind you.
Just use the cruise control button and you should be fine!
Speaking of cruise control... on uneven terrain, my cruise control setpoint automatically increases after I top a hill .. it gains a couple MPH each major hill and doesn't come back down later... Anyone else have this?
huggy_d1
Old Jul 24, 2004
vietstylez's Avatar
i had the v1...awesome radar, i cant stand riding with my friends passport 8500 just cause it has no arrows and it keeps you guessing where the cop is. i love the arrows for the v1
Old Jul 26, 2004
meseetree's Avatar
meseetree is on a distinguished road
you want it down low because when cops shoot laser at you it's aimed at the lisence plate but it does affect the rear detection it depends on what you want.
Old Jul 27, 2004
by the time iy alerts to laser...you're toast. The beam is so fast and narrow there is almost nbo detection from it bouncing off other cars. Radar can be detected rather easy,,,laser it much harder to get warning on.
Old Jul 28, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Look into K40 stealth mount systems. THey go in the bumpers of the car and there is a display that goes anywhere you want. And they will pay for any tickets you might get.
Old Aug 5, 2004
Blue_Honda_Civ's Avatar
I drive a jeep to compensate for my tiny pee pee
Blue_Honda_Civ will become famous soon enoughBlue_Honda_Civ will become famous soon enough
on the Valentine site they say to put it in the blue strip of the windshield
also with the V1 you can continuosly upgrade it
Old Aug 5, 2004
http://www.valentine1.com/laserhowto/ here is the link to the site
runawaykinms
15
Mar 22, 2019 10:32 AM
JMKendrick
Sep 16, 2015 06:17 PM
carid
Aug 8, 2015 05:05 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
RallyEX
40
Aug 24, 2003 06:08 PM
