Amp Overheating
Old Jul 13, 2004
angelswin's Avatar
angelswin is on a distinguished road
Amp Overheating
I was wondering if anyone has had any trouble with running a phoenix gold amp.My problem is I live in Fresno and its in the 100's my amp is in the trunk lying down on its bottom.When I touch the amp in the afternoon after my car has been sitting the amp is already really hot.I run it for about 20 minutes and the amp shuts off.Any Ideas how to cool off our trunks.
Old Jul 13, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Park in the shade? Open the back seats to let the hot air escape? Ride with the back seats open with the two center air vents pointed back there to cool it down? Wire up a 12V fan(s) to the remote wire to blow on your amp to cool it? And, If all else fails, get a small bag of ice, and wrap it in a towel to absorb the moisture, then, sit it on the amp for a few minutes to cool it before powering up.(Yes, I've seen this done at a competition, and it worked for the guy that did it.)
Old Jul 13, 2004
MegaHurtz's Avatar
I think having fans would be the easiest way...
Maybe wire them with constant power or switched power such that the fans turn on when the car turns off.
Old Jul 13, 2004
MegaHurtz's Avatar
You can probably achieve the latter with a relay
Old Jul 13, 2004
or hook them up to remote wire for your amp. come on with amp.
Old Jul 13, 2004
MegaHurtz's Avatar
Personally I would go with constant power. I would bet dollars to donuts that it never kills your battery, and it would definitely make things a LOT cooler.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
raymondxcho
Sep 29, 2015 09:00 PM
Mc7602
Sep 17, 2015 02:01 PM
