need help
Old Jun 30, 2004
Farage's Avatar
I like you! do you like me?
need help
hey, i just installed my audiobahn box and its amazing. however, the check engine light is on. i think it might be because of the remote wire being attached to a certain fuse. does anyone have any advice?
Old Jun 30, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
You know it starts flashing at 7.5k, then comes on permanent at 10k right? This is for the oil change reminder. Most times the guys at Jiffy Lube won't be resetting that for you. Its in the manual how to reset it.
Old Jun 30, 2004
Farage's Avatar
its not maint req, the check engine light.
Old Jun 30, 2004
doubledeuce2k2's Avatar
disconnect the ground wire ( or positive) from the battery, then start the car and let it idle a while (like 10 minutes)
search tech stuff for resetting the ecu, it's around
Old Jun 30, 2004
takumi's Avatar
takumi is on a distinguished road
Umm, I think the ground wire is negative (black one).
Old Jun 30, 2004
Farage's Avatar
i screwed around with the remote wire and the light went off. thanks for the tips guys.
