Optima Red Top: Confused about which model/Group# I should get.
Old Jun 26, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
I noticed in an older thread, people have used these Optima batteries:
Model #9004-003
Group #51(R or N?)
Group #74
I know Group #51 is our stock sized battery but I can't find it as a Red Top. Only as a Yellow Top.
What's the difference between these models? I've been looking all over for the battery and although I can find them, no store (not online) seems to want to help me. Sears is an official dealer of Optima, and if they don't have the one you won't they won't special order it. AutoZone says Group 51 only exists for the Yellow Top (after ordering a RedTop from them and received a Yellow two days later.)
I REALLY need a new battery and I want this one but it seems like I can't find much help. It looks like SummitRacing.com is my only option, and if it's not - what are my other options on how I can obtain the right Red Top?
Old Jun 26, 2004
MegaHurtz's Avatar
Get a yellow top, they are better for audio
I am not sure if you want the normal or reversed terminals, but if my memory is on the ball, you would want the reverse terminals.
Old Jun 26, 2004
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
You want a yellow top. You can deep cycle (completely deplete) a yellowtop all you want and not hurt it. Red top is more powerful but can't handle the deep cycling. Blue top is for marine use and is meant more to be slowly drained over a long period of time- and shouldn't be deep cycled.
Old Jun 27, 2004
All Eyes On Z
I don't need a Yellow Top. I need a starter battery. There is nothing on my car worth the Yellow Top. RED, RED, RED.
Old Jun 27, 2004
MegaHurtz's Avatar
Yellow, believe me
Old Jun 27, 2004
All Eyes On Z
That's not helping me towards what I want more than what you think I need... in fact you just said it yourself. "They're better for audio." Well, why would I need that if my stereo is stock?
I'm already aware of the capability differences between the Red, Yellow and Blue, thanks.
Old Jun 27, 2004
opto_isolator's Avatar
You can pretty much use any of the "Red Top" batteries - I just installed a 75/35 this weekend I bought at autozone for $129, nice battery! The main difference between the different red tops is the physical size, and CCA - the 75/35 is around 910cca I believe, the 74 is 980cca I believe, and is physically larger. Both are shorter than the stock battery. To compensate I ghetto rigged it to fit - took out the battery box / shroud, and set it on a 1/4" piece of oak board temporaily until I can figure out a more permenant way to raise it for the battery tie down to work properly....
Old Jun 27, 2004
MegaHurtz's Avatar
What would you need it for in a Civic if not for audio?
Since this is an audio forum, generally we can assume any questions are audio related if you do not specify. You didn't say anywhere that your stereo was stock.
Old Jun 27, 2004
All Eyes On Z
Thank you opto.
MegaHurtz... it's called "I.C.E. & Electrical. Maybe I could've posted in Products & Parts, but since everything that works electrically in a car begins by a battery, this forum looked more reasonable.
My second post said in bold I had nothing worth the Yellow Top on my car, and I don't plan on having anything on it like that anyways. It's all good though.
Old Jun 27, 2004
MegaHurtz's Avatar
Then can I ask what you need an upgraded battery for? Just curious
Old Jun 27, 2004
civic01vtec's Avatar
LMFAO at slammed
you own bro
Old Jun 27, 2004
Seriously, red top will help you for the first few seconds of starting. You can just use a stock battery for that. At least with a yellow top, you don't have to worry about anything draining and killing the battery. Even the yellow top is a better starting battery than stock. So red is just a waste for you. Spend the extra $$ on something else and just get a stock battery.
Old Jun 27, 2004
Uhh - batteries go bad - maybe he wants to buy a good one?
Old Jun 27, 2004
MegaHurtz's Avatar
So then why spend a mint on an expensiv battery that he doesn't need?
Old Jun 28, 2004
All Eyes On Z
Good point, but somewhere down the line, I want to relocate this battery to the trunk, and Optimas are good for that purpose.
My stock battery is dead.
Let's ask him.
... he said because it's what he wants.
Old Jun 28, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
I know this is noobish, but...I have about 550 watts RMS running in my trunk, and am looking at a new battery. Should I get a stock starter battery and a yellow top in the trunk, or can I just get one and be ok? Don't mean to hijack the thread or anything; should be a pretty simple answer.
Old Jun 28, 2004
MegaHurtz's Avatar
Just get one battery and u will be fine
Old Jun 28, 2004
jwalker87's Avatar
Bodacious Member
yellow or red, if I'm running an audio system as well as the starter from it?
Old Jun 28, 2004
All Eyes On Z
^^^I'd say Yellow. I think that MegaHurtz and I can agree on the fact that Yellow is fine to start your car with but the deep cycling from the Yellow has the advantage for your situation.
Old Jun 28, 2004
jwalker87's Avatar
Bodacious Member
i just went to advanceautoparts.com, and put in that I have a 2002 Honda Civic, and they say the D51 is what fits our cars. Since the title of the thread IS about which model to use...
Old Jun 28, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
group 74 (standard size, can buy at an autoparts store such as advance, etc.) will fit fine. you can't use the plastic battery condom thing that slides over the stock size, but it will fit.
Old Jun 29, 2004
All Eyes On Z
I went on and got the 9004-003. The car cranks up surprisingly fast.
Old Jun 30, 2004
Logan3024's Avatar
Why did you waste an extra 50$? You would have been fine with a 40$ autozone battery.
Old Jun 30, 2004
All Eyes On Z
No offense, but did you read and reply to this thread to prove a point? Because you must've missed me saying that I want to relocate the battery to the trunk.
Old Jun 30, 2004
Logan3024's Avatar
Autozone batterys can be relocated to the trunk to.
Im not trying to prove no point, the only obvious point i see is that you have no need for a red or yellow top
Old Jun 30, 2004
fonto's Avatar
The LA Clipper
alot of people think that Optima batteries are a sham and a waste of money...some people think it is better just to go with the biggest battery that you can fit in your car with the most cold cranking amps (regardless of price).
Old Jun 30, 2004
tgz2k1civic's Avatar
tgz2k1civic is an unknown quantity at this point
yellow is the way to go but if you running multi amps or running any eclipse or JL audio w5,6,7 then you might want two batteries....
Old Jul 1, 2004
All Eyes On Z
Well, I got what I want and I'm happy.
I think a lot of people get a lot of things for their cars that I think are crap. For me, I choose to learn the ups and downs from my experience, and all I need is the interest in it, as well as enough positive feedback. I got that. So down the line, when my next battery is some cheap-o Wal-Mart battery, or an Optima Yellow, I'll make my own judgement based on what i want. But as far as my knowledge about batteries has taken me along with the experience i will have seeing how the battery performs, I'm content. It suits me.
Old Jul 1, 2004
fonto's Avatar
The LA Clipper
Old Jul 1, 2004
Logan3024's Avatar
SlammedBlu
what kind of warrenty does it come with?? 2 year or what?
