Want to disable that #*&% brake pedal interlock
Old May 10, 2004
gints's Avatar
gints is an unknown quantity at this point
Question Want to disable that #*&% brake pedal interlock
I'm not sure if this is an electrical issue or not...
My recently acquired DX sedan is automatic; incidentally, also my first auto tranny car in 19 years.
It has that stupid brake pedal interlock feature, you know, step on the brake before you can pull the lever out of PARK. There is no describing how much this "safety" item pisses me off. How can I disable/bypass it?
Thanks
Old May 10, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
umm.. I don't think you can disable that. All automatic cars are like that.
Old May 10, 2004
LudlamTheory's Avatar
i boogie for the raindrops
why do you wanna disable it
and if you give me a good reason, ill tell you =)
Old May 11, 2004
gints's Avatar
I'm not sure what qualifies for you as a good reason, but I 've NEVER EVER left my son in the car with the engine running. That, as I understand was a prime reason for that kind of safety measure.
Also, I don't see the need to put on the brakes to drive away... never have to do that in my 5 Liter 'Stang. Just dump the clutch and hang on.
Almost as ridiculous as clicking the START button to shut off your computer?!
Old May 11, 2004
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
Its there for a reason. Safety. Every automatic car has that. Live with it. Are you one those also that will be shifting his auto from D2-D3.
Old May 11, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
heh...i think i know of a way to disable it but i wouldnt tell you either unless you have a very good reason to have it dissabled... :P
Old May 12, 2004
basically, just take the entire section out around the shifter, the whole plastic console. then look on the left side of the shifter area and tp your brakes, youll see a small actuator move back and forth. what you want to do is disable it from its existance. either take it out, jam it on open, wire up some new relays, etc...
Old May 14, 2004
gints's Avatar
Thanks to all for your assistance/opinions.
honda.lioness
Aug 6, 2015 11:58 AM
DerbyDad03
Jul 27, 2015 11:34 AM
wootah88
Jul 21, 2015 10:22 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
Causemo
Jul 5, 2015 06:42 AM
