stereo help! please! no tunes!!!!
Old May 5, 2004
fondahonda's Avatar
fondahonda is an unknown quantity at this point
Question stereo help! please! no tunes!!!!
I have a kenwood system that is in need of some help please
heres what I got
kenwood deck excelon 617
kenwood components mids and highs in the doors with x overs
kenwood excelon 6x9 3 ways in the rear deck
(1) 10" JL audio sub w3 6 ohm
pushing the fronts and rears is a
5 chanel kenwood with the sub left off
for the sub
is kenwood 2 chanel bridged
let me know if ya need more info on watts and model #s
I have had several problems with amps both being repaird for out put I think
but both should be in working order.
the sub amp has been in storage untill today to test
the first symptoms were the volume started to cut out at 35 full blast then a little by little it would cut out at lower levels until nothing at all. all of this over a two week period
my first guess was the head unit. had it taken in for a look see.
they said it was fine lost 20 bucks there !@#$#$%^&
went home and decided to hook up the sub amp to see if it plays just the inside of the cab
it barley plays at full blast but has a nasty bump when you turn it off
you guys please help me if you know whats wrong. I dont want to give this stereo guy any more $$$$ than I have to
If you need more info email me and ill see if I can get anny more info that you might need thanks in advance
fondahonda
you can email me at blackthree4me@yahoo.com
Old May 5, 2004
rackness's Avatar
rackness is an unknown quantity at this point
you will get alot better responses if you post in the I.C.E. forum. lots of good people in there very knowledgable about audio equipment.
Old May 5, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
I have a kenwood deck not an exelon but running my speakers off of the stereo amp and if i play it for a while at about 27 max being 35 it does the same thing. i think its just that kenwood suck first one i have owned and never had this prob on other stereos and i had about 10 different ones. someone told me it was the amp in the stereo.
Old May 5, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
its your deck... the same **** happen to me... I sold my box and my amps thinking it was that .. 1 month later ... problem comes back and i would happen everyday.. i would have to turn it off for least a hour and then it would good for like 30 minutes.. I always play my music full blast, after a while the internal amp just goes... time to get a new get ... go for kenwood 915 ... best deck out period
Old May 26, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
check your wiring cuz i have the same problem, one of my speakers were in reverse polarity and thats the reason it goes off after a while..
Old May 27, 2004
fondahonda's Avatar
found out yesterday that both amps were bad one the four canel had one dead output
the other would not power up hmmm have to take that one back to the repair shop
was suposed to be repaird any way replaced amps with
alpine MRP F 240 for the fronts
fosgate p 3001 for the sub
sound pretty good about the same as before on the fronts
but the mono sub made a huge diferance realy woke up the 10" JL
thanks for all your help and keep up the good work
fondahonda
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
zeshan7616
Sep 15, 2015 12:24 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
