size for front speakers (opinion)
Old May 4, 2004
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
should i go with 5.25 for the front or 6.5...
Im not concerned with power increases with going for a bigger speaker, just wanna know for reasons regarding fitment and stuff...lol
Im debating over Alpine type-r component sizes...so help me please!!!!
also does anybody know if their 6x9's sound good, the type r's that is???
Old May 5, 2004
djspot's Avatar
fuk tha man!
somebody come on!!!!!!
Old May 5, 2004
guamcivic2k1's Avatar
YoUnG N SuXsExFul
arent' the front speakers 6 1/2?
Old May 6, 2004
djspot's Avatar
fuk tha man!
Im not sure what size they are thats why Im asking....wow only one person responding...thats ****in' wack!
Old May 6, 2004
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
on a coupe the fronts are gay 6.5s stock, i put some infinity 6.5s in and it sounds great; had to bend some metal though.....and remember to use short screws otherwise windows doesn't go down (learning the hard way)........when i say short i mean like no longer than 1 inch or so
Old May 6, 2004
t3a5p00n's Avatar
t3a5p00n is an unknown quantity at this point
yea the fronts are 6.5"s. I'd say go for the 6.5"s although most aftermarket 6.5"s will need some modification to fit, it will be worth it.
also, i think the rears are 6x9's but 6.5"s in adapter plates would be nice.
Old May 6, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
6.5 front-6x9 rear
I got 6.5's on mine Audiobahns, the whole speaker won't fit on the hole, you can make a bigger hole to make it fit, but if you don't wanna cut a bigger hole somehow you could put 3 or 4 screws to get the speakers mounted, the speaker will have about an inch height from the metal frame, but you can make it fit under that plastic cover...
Old May 6, 2004
thomusvoo's Avatar
Newbie Member
thomusvoo is on a distinguished road
this is a no brainer...
!!!!>>>>>>>> 6 1/2 COMPONENT <<<<<<!!!!!
Old May 6, 2004
MegaHurtz's Avatar
^^ I second that notion
Old May 6, 2004
doubledeuce2k2's Avatar
a 6.5" speaker gives you like 30% more cone area.... read: around 30% more bass.
also can get a little lower. components will be your best musical option, but there is a little more install work with them. searching will help you out a lot, some speakers are tougher installs then others.
Old May 7, 2004
djspot's Avatar
fuk tha man!
ok cool....basically I wasn't sure if our stock speaker was a 5.25 or 6.5
anyways....do u guys think I should go with 6.5 components in the back too??? or stick to 2 way 6x9 coaxials?
Old May 7, 2004
shmik1's Avatar
I think all alpine's type r series is good stuff
Old May 7, 2004
you don't need to waste money on components in the back...
any moment someone will tell you you don't need rear speakers anyways, so here is the warning. but remember it's all preference, some people really like having rear speakers, or use rear speakers as midbass
Old May 7, 2004
reyesvazquez's Avatar
reyesvazquez is an unknown quantity at this point
i go with 6.5and another thing is tha to mount mines i use the stoc speaker,u need to tearup the stock one but it work,after u done takin the speakerout of the plastic frame that is mounted u have a nice mounting frame for ur aftermarket spakers!
Old May 7, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Would it really have been that much harder to type the above statement in proper english with puncuation?
Anyway, back to the topic at hand, in the COUPE it's 6.5 in the front 6x9 in the rear, in the sedan it's 6.5 all around. Almost any 6.5 will fit with a spacer, and a 6.5 does not give you 30% more bass than a 5 1/2, that all depends on the speaker charecteristics. I've heard 5 1/2's with more midbass than a 7" speaker.
If I were you I would leave the rear speakers stock, or disconnected, and spend the money on a good set of front speakers with an amp.
Old May 7, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
just cut a 1/4 or slightly thicker mdf piece that you can mount the speaker on so its spaced farther from the window. Just trim it on the bottom right corner so the door panel will fit over it. Also when i first got into audio i got some alpine 6.5 type s in my old civic and they sucked. I think the wierd stock plastic speakers are better which isnt a surprize. most cars come with higher quality speakers than most of the low end audio speakers. I recommend chooseing something better than the type r you wont be impressed with it.
Old May 8, 2004
djspot's Avatar
fuk tha man!
thanks for the advice audioefx3, which would you recommend for the same price...I did have a sample of the type r components, I thought they sounded pretty nice....for the rear, I'd like to fill it with some a nice high/mid sound....cuz if I have passengers won't they be basically overwhelmed (spelling???) with the bass from the subs, and almost no mids or highs? or would the front components fill that void good enough?
Old May 8, 2004
Mystic3030's Avatar
I have four 12's in my trunk, and no rear speakers, with components in the front. From the rear you can hear the highs and mids just fine.
Old May 8, 2004
MegaHurtz's Avatar
Who installs component speakers to get bass?
Old May 8, 2004
well sorry,english is my second language,but i just giving my opinion
Old May 9, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i agree the sps/type s 6.5" speakers sound like shiet in our civics...
i tried them and they really sucked
Old May 9, 2004
turboslug's Avatar
Super Hoser
ok, lets say i'm going to buy type r comps..
will a 6.5" type r produce significantly more bass than a 5.25" type r?
i'm thinking of installing 5.25" type r's because then i might not need to cut the sheetmetal on my door...
also, i want bass from my speakers because i dont want a sub...
Old May 9, 2004
djspot's Avatar
fuk tha man!
aaaahhh you robbed my post...lol...its cool though cuz I wouldnt mind knowing that either....
well about the rear speakers...if i I do go with them would 6x9 type r's be good enough just to fell out the sound more????
Old May 9, 2004
front bass is always nice. that's why a lot of people improve front midbass speakers instead of throwing another sub in the trunk, and why there are 3 way component systems.
i wouldn't spend much on the rear fill really.
Old May 9, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
6.5 components up front and 6x9s in the rear.... fade your stereo all the way to the front and slowly fade it back just till you hear the rear speakers,,, then set the balance about 2 to the right passenger side. This will give you a nice concert sound and eliminates a need for a center channel. this is how my old system was set up at the car stereo shop and the stageing was perfect,,,,if you do if right you should have a hard time finding were the music is comming from when sitting in the drivers seat. No need to spend alot on rear speakers but the best for the front that is were the imaging is.
Old May 9, 2004
oh yeah for the front i had JL components XR650 sounded mint blasting slayer. they have even better ones for 2004 not sure on price or name but im getting them.
Old May 10, 2004
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
I had a set of type r 6.5" components in my doors and they sounded nice. You need a spacer ring to bring it out from the door tho. Now i have 7's in my doors with no problem which are even deep then the type r's.
As far as the type s components go, in the past 2 weeks i've instlled 2 paits in 2 different s2000's and they sound awesome. The type s was redesigned and is just as beefy as my type r's. The type s also come with a specific spacer for the civic that allows them to pretty much bolt right in.
Old May 10, 2004
turboslug's Avatar
Super Hoser
you also had to cut away some of the sheet metal, right?
Old May 11, 2004
custom2k1's Avatar
I cut sheet metal away when i did the type r's originally. I didnt cut any additional when i did the 7's.
ademarco6
Nov 16, 2001 10:19 PM
BabyLX
Nov 16, 2001 05:53 PM
ademarco6
Nov 12, 2001 06:52 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
