checking amps
Old Apr 28, 2004
scarpones's Avatar
scarpones is an unknown quantity at this point
checking amps
just a quick question if anyone knows
how much amps should the remote wire be pulling?
i have been having problems with my system, and for some reason its pulling between 15-20 amps which seems like alot to me because thats how much my B+ wire pulls
i know this because it blows 15 amp fuses, but not 20.
any thoughts?
And also, how much would a multimeter cost with the ability to test up to 50amps or so....mine caps out at 10amps and the fuse blows.
Old Apr 28, 2004
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
How many watts is your amp?? Who did your wiring to the amp? Double chech your wiring. Also where is your remote wire connected, to the radio? or do you have a kill swith for the amp?
Old Apr 28, 2004
scarpones's Avatar
each of the amps use 8awg wire from the batt. JBL300.1 and RF 201S
i installed it all and it is wired corectly.
the remote isnt connected right now, cause the remote-out on the deck is blown
and it keeps blowing the acc fuse
someone told me the amp is 1-3 amps?
sound about right for the remote wire?
Old Apr 28, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
I blew the fuse in my remote wire once. If I remember right it was 1 amp ... maybe even 0.5 amp ....
Old Apr 28, 2004
LudlamTheory's Avatar
i boogie for the raindrops
remote wires shouldnt be pulling more than .1 amps. the remote wire on pioneers maxes out at 200 mA (.2 amps), and ive seen people run 3 amps off it.
Old Apr 28, 2004
scarpones's Avatar
well this is my new theory of what might be wrong...maybe there is something wrong with the B+ wire and the amps are pulling current from the remote wire...cause it wants to pull just under 20amps.
sound logical?
Since my remote is blown the my deck...would the acc socket be the best place to hook it up?
Old Apr 28, 2004
Regularjoe's Avatar
what exactly is the B+ wire?
Old Apr 28, 2004
Silver_JS5's Avatar
Silver_JS5 is an unknown quantity at this point
B+ wire is the battery/power wire....runs from the positive terminal on the battery, to a fuse, then to that terminal on the amp to give power....
Old Apr 29, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
i dont see how you could have pulled 15amps from the remote wire and still have a working deck
Old Apr 29, 2004
Regularjoe's Avatar
You have a short somewhere man. Thats the only reason the remote wire would want to pull current. Seriously.
Old Apr 29, 2004
short would be inside the amp or somewhere in your install, also, what gauge wire is your remote?
Old Apr 30, 2004
scarpones's Avatar
well the deck remote is not working anymore...but the rest of it is
the remote wire was really thin, probebly around 22 awg or semething
but i used a 8awg wire when i hooked it up to the batt.
i have 2 amps...and they both do work...so i dont think the amps are shorted...maybe the wiring i guess...not sure
Old Apr 30, 2004
22 gauge can NOT take 15 amps of current over 20 feet
thats like sucking a basketball through a garden hose
Old Apr 30, 2004
Silver_JS5's Avatar
if your running 22 gauge, i might change that if i were you...maybe down to 18...that's what i'm running...
Old May 1, 2004
scarpones's Avatar
i know 22awg cant..amd it popped the fuse, so i hook up a 8awg wire with a 20amp fuse and it didnt pop
dam this is frustrating
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
