More topics for discussion
Old Apr 25, 2004
fonto's Avatar
The LA Clipper
I'm bored and curious so I will ask a few more questions
Question 1. Since have 1500+ RMS watts in my system is it ok that I am using 4 gauge wire to a distro block that splits into a 4 gauge for each of my two amps?
Question 2. I have my amps and cap grounded to the bump between the backseat and the trunk...where would be a better place to ground? One the side of the trunk somewhere?
Old Apr 25, 2004
WhiteRabbit's Avatar
1500+ rms, id definitely be running 2 gauge minimum with 4 guage to the amps
whats wrong with the ground as it is now? is it invisible? is it clean? if it aint broke, dont fix it!
Old Apr 25, 2004
MegaHurtz's Avatar
1. Run 2 or even 0 awg to your distro block if you have 4 awg to each awp
2. The ground is fine
Old Apr 25, 2004
fonto's Avatar
The LA Clipper
When I went to ID Matt pointed out all of these things that were making my voltage drop...he said I should do the Alternator power wire with 4 gauge and that I should reground to the middle or back of the trunk. He said the 4 gauge was ok, but I firgure that it is important to up grade that...he said it would be worth it to spend a day to rewire everything...thats why I am asking.
Old Apr 25, 2004
fonto's Avatar
The LA Clipper
I was thinking that instead of running a completely new line of 0 gauge wire that I should just run a second line of 4 gauge to the back. This will help so I don't have to completely rewire my amps and cap...I could just use my fused distro block within 18 inches of the battery with 0 gauge going to it, and 2 4 gauges going out.
anything wrong with doing this?
...this sounds like a summer project!!
Old Apr 25, 2004
not at all, we do it all the time in boats and such.
Old Apr 25, 2004
fonto's Avatar
The LA Clipper
Thanks WR
jtcavey
Sep 30, 2015 02:18 PM
juicetayne
Sep 30, 2015 11:02 AM
viperGTS
Jul 27, 2015 08:40 PM
