amp problems
Old Apr 21, 2004
scarpones's Avatar
scarpones is an unknown quantity at this point
amp problems
I turn my car on one day, and both my amps are not working. so i mess around trying to get them going, and realize they aren't turning on..so i check the remote wire and its fine, but for some reason, the remote wire output on my pioneer deck isn't putting out any voltage(checked with multimeter) so i hook up my sub amp to the acc. socket and it blows the fuse. i try my speakers amp and it works find w/o blowing and fuses?
so my question is what could be wrong with my sub amp. its a JBL 300.1. all other wiring is fine and no fuses are blown.
any ideas?
Old Apr 21, 2004
7thgencivic9's Avatar
7thgencivic9 is an unknown quantity at this point
double check your ground wire just to make sure...make sure wherever you grounded it that the paint is scratched off...i installed a system in one of my friends ride and everything worked fine for about an hour...then we turned off everything and when we got back in the car we turned it on but the amp didn't work...so i checked the ground and noticed that i needed to scratch off the paint and i did and it worked fine...you may not have that problem but just an idea...hope it helps
Old Apr 21, 2004
scarpones's Avatar
yeh everything is grounded properly...ive installed a few systems before...but this is a new problem...i been hearing i might have a short on the amp board...if so, anyone know how to fix?
Old Apr 21, 2004
LudlamTheory's Avatar
i boogie for the raindrops
you also my have a short on the remote wire somewhere. try hooking up the amp directly to your battery under the hood with some short cables, see if it turns on
Old Apr 21, 2004
scarpones's Avatar
but doesnt the remote wire need a voltage as well for the amp to turn on?
or do u mean hook them all up to the batt?
EDIT: i also tried using a new remote wire...it blew the acc. fuse as well, so its defenatly not the wire itself.
Old Apr 21, 2004
mmm
amp problem
deck remote is also permanently dead most likely
open up the back plate and side plates of the amp, and take a pic for me (preferably really high res so i can see the internals)
if the site wont let you upload it, email it to ludlamtheory@hotmail.com
Old Apr 21, 2004
scarpones's Avatar
alright...i'll take and send it after work tomorow
Old Apr 23, 2004
scarpones's Avatar
ok i took some pics...but they are 350-400k so im gonna email them to you Ludlem
i can't see anything wrong or any burnspots, but you prolly know more.
thanks in advance
Old Apr 23, 2004
i never got em =(
or
dubitalie on aim
Old Apr 23, 2004
scarpones's Avatar
k i sent them again
shitty *** sympatico
Old Apr 25, 2004
scarpones's Avatar
no ideas ludlum?
Old Apr 25, 2004
i see nothing wrong...
have you tried each amp individually?
Old Apr 26, 2004
scarpones's Avatar
yeh i have...but for some reason, my speaker one is blowing fuses now too...so i think my wiring is shorting somewhere, so i think im gonna rip it all out and redo it all
or is there anyway to test the wires if they are shorting or not w/o all that work?
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
