So i call up my Honda deal to fit some speakers in.
Old Apr 13, 2004
Schizophonic's Avatar
Schizophonic is an unknown quantity at this point
They don't do upgrade honda speakers but if i buy some after market one, they will fit them in.
For £50 and £60 for the back!!!
WTF!?
But if its to get the job done properly, then i might go for it.
Old Apr 13, 2004
doubledeuce2k2's Avatar
wherever you could go and buy speakers would do it for less than that. and likely do it better. thats a lot to pay for something you just connect 2 wire too and forget about...
Old Apr 13, 2004
MegaHurtz's Avatar
Do it yourself. Check the DIY section. You can take the whole back half of that car apart in < 30 minutes
Old Apr 13, 2004
Seriously do it yourself. There was a time when I couldn't do any of that stuff, but since have taken my entire car apart to install dynamat and stuff. Just search around--there's tons of info here.
Old Apr 13, 2004
cambo's Avatar
I wish I was asian
since you're giving money away...can i have some?
Old Apr 13, 2004
MegaHurtz's Avatar
Don't be afraid to jump into a project like this.
It's very easy to do, use common sense and watch what you do, think things through and you will be fine.
I would not lie.
Old Apr 14, 2004
I've seen the DIY section in k-series.com and it looks a bit 'baffeling'
Having an older brother, he's told me that some cars, once things pop out some things might not go back the way it is.
I wouldn't mind doing it, (i think) but just that i don't want to wreck another car.
The speakers are going to be about mind range (£50) and then if i go with the Honda Dealer option then thats already £100 inc. VAT!
I'm off back to uni soon, and i'll be there just over a month. I'll keep on thinking, and checking. So when its the right time, then i'll do it.
One thing my parents pointed out. I have stock Stero (OEM). Will the upgrade speakers be worth it than the stock? Should i get a new head unit first or go with the speakers?
Old Apr 14, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
the stock headunit will do fine, but a aftermarket headunit is always better.
jessicakaybby
Apr 20, 2015 12:11 PM
tattedlariat
Apr 17, 2015 03:26 AM
Bartkat
20
Feb 19, 2002 01:29 PM
