which 12 to get?
Old Apr 10, 2004
PeN8503's Avatar
PeN8503 is an unknown quantity at this point
which 12 to get?
ok i definately want 1 12, but i need help deciding.
i want it to be loud, deep, clear. put it this way, i love rap music alot.
i have done a little research and im deciding between
- jl w6
- jl w6v2
-jl w3v2
-alpine type r
i wanna spend 200-300 on the sub. and i will most likely buy it brand new from ebay.
so someone help me out on the differences between these, or people who already have these, tell me what u think of them?
i would also appreciate any other subs u think are compareable to these...
thank you
Old Apr 10, 2004
MegaHurtz's Avatar
I'd say the w3v2 would be ideal for you
Old Apr 13, 2004
KnocturnalEM2's Avatar
I am your Mom's Hero!!
Dont waste the time with the type r...go with the w6v2!!
Old Apr 13, 2004
SubstanceX's Avatar
SubstanceX is an unknown quantity at this point
go with the W6V2
Old Apr 13, 2004
MegaHurtz's Avatar
The w6v2 if at all like it's predecessor has dual 6-ohm coils. These subs work best in groups of 3, as you are able to get a 1 or 4 ohm load in that situation, otherwise you are stuck with 3 or 12.
Go with the w3v2.
Old Apr 13, 2004
SQCivic's Avatar
SQCivic is an unknown quantity at this point
W3v2
Old Apr 13, 2004
LudlamTheory's Avatar
i boogie for the raindrops
w6v2 is now a dual 4 ohm driver.
if you want it loud and low, a 15L7 would be much louder, and probably play lower, the w6v2 is more sound quality oriented
Old Apr 13, 2004
WhiteRabbit's Avatar
for rap music, i would definitely go the type R route or w6v2. both have het ability to play those warm low tones, the w3v2 is more of a rock driver with quicker transients and brighter response
Old Apr 13, 2004
the w6v1 may be the best for you of all, its warm yet can be quick for fast beats, kind of the best of both worlds.
nowadays they are cheap, and they can handle a crapload of power, yet are efficient enough to get reasonably loud off low power.
however, like said before, they only come in a dual 6 ohm version, so whatever amplifeir you get to power it will have ot be 2 ohm stable, and ideally rated for at least 3-400 rms at 4 ohms, much less two.
and whatever its rated at for 2 ohms, you lose power since it runs at 3 ohms.
but sound quality wise, it may be the best of everything for you. Lud and I have discussions with a guy running a trio of the 10's in his civic with 400 rms TOTAL hitting in the 140's!
Old Apr 14, 2004
shmik1's Avatar
Type R can be had for cheap at hookedontronics.com
