Help Please- LEDs on M3 mirrors
Old Mar 23, 2004
y2k1civicman's Avatar
y2k1civicman is an unknown quantity at this point
I just got done wiring my power M3 mirrors with LED. I'm positive everything is wired correctly. Neither set of LEDs are working. The LEDs works; I tested them from battery. What could be wrong???
Old Mar 23, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
do your regular turn signals work ? if not you might have blown a fuse.
is the led ground connection grounded properly ?
Double check the wiring, you can never be too sure. Until it works.
Old Mar 23, 2004
Regular turn signals work. It is connected to the turn signal ground and red turn signal wire. I worked on it for almost 2 hours today. Still don't know, what's wrong?
Old Mar 24, 2004
MrWong's Avatar
Bushido
Hmmm is there a third wire ? one to connect it to a constant source of power ? The turn signal wire might act like a on/off switch for the led, just a thought.
Old Mar 24, 2004
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
There should be 3 wires. One goes to parking lights, one to turn signals and one ground. Run the ground right to your door tho, dont bother to go to your turn signal ground.
gearbox
Lighting
467
Oct 16, 2017 02:03 PM
Whelan
Nov 19, 2003 12:35 AM
Ike
Nov 16, 2003 09:02 PM
