2 channel amp + 1 kicker 4ohm solobaric
Old Mar 18, 2004
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
i was told its possible to wire a 2 channel amp to a single woofer is this true???
Old Mar 18, 2004
Civicly02's Avatar
yes it is. You just bridge the two channels to run on that one amp
Old Mar 18, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
assuming the amp supports bridging..make sure you verify that before attempting it.
Old Mar 18, 2004
sadboy916's Avatar
what would be a good amp to do this with im looking for something like 400x2 or 500x2 right.
Old Mar 18, 2004
LudlamTheory's Avatar
i boogie for the raindrops
technically you could wire 16,384 channels together to one sub if you wanted....
Old Mar 18, 2004
sadboy916's Avatar
what about 16,285 channels or would that be to many
what amp do you think would work best
Old Mar 18, 2004
16285 would be harder, its not a multiple of 2...
32,768 would work though
as to the amp, is it an L5 or an L7?
and is it single 4 ohm or dual 4 ohm...
Old Mar 18, 2004
sadboy916's Avatar
Its a 12" l5 4 ohm
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
General DIY
Sep 25, 2015 08:02 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
