remotes....
Old Feb 17, 2004
Sampsonite's Avatar
Sampsonite is an unknown quantity at this point
remotes....
I was just wondering if I could use the OEM keyfob with my security system. I have the Black Widow BW 2800. The online specs say it is code learning, so maybe? If i can how do i program everything? Thanks.
PS, I would've consulted the manual had i been given one and had i been able to find it online
Old Feb 20, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Probally not the fob and remote might be using a different frequency.
Old Feb 20, 2004
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
i know that code alarm, and probably something from DEI will allow you to add security to your cars and allow you to use your factory key fobs.
as for using what you currently have, it might be possible, but i would have the slightest clue on how to do it.
i think the only drawback to using the factory key fob is range, i bet it wont be as good.
