Want to get high?
Old Jan 17, 2004
quick83's Avatar
quick83 is an unknown quantity at this point
Want to get high?
To me my car has too much bass coming from the front speakers and not enough highs, plus they don’t sound clear. Right now I have Polk db 650 up front, and the stock tweeters. In the back I have Polk db 690's and a 12" sub.
Should I just get new tweeters to replace the stock ones? (Will that give me better, clearer highs)
Or should I get components and are there any you would recommend?
Old Jan 17, 2004
Tre's Avatar
Tre
Tre is an unknown quantity at this point
Can't go wrong with mb quart components, if you crave Highs. I got 'em, I love 'em, and highly recommend them!
Old Jan 17, 2004
7thGenerasianCivic's Avatar
Get some highs. Or you can just add to your stocks.
Old Jan 17, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
if you really want to save money, install a crossover, if you don't already have one. you can find them many places.
here:
http://www.onlinecarstereo.com/CarAu...?CategoryID=14
or here:
http://www.woofersetc.com/manufacturer.asp?2=1086
that'd be a good start. if you wanted to spend a little more, then a component set would be a good idea. but if you want to spend as little as possible, get a crossover, that will filter out the low end frequencies for the least amount of money. i'd say that a comp set is a good idea, especially if you are planning on upgrading your car audio more, and are into modifying your system. they are a good way to get the full spectrum out of your audio system, but if you are just looking to filter out bass for as cheap as possible, then yes, a crossover will fit your needs, if you don't already have one.
Old Jan 17, 2004
alex053's Avatar
i got the hook up on quart...pm me
Old Jan 18, 2004
Sim012's Avatar
Sim012 is an unknown quantity at this point
hydro...
Old Jan 18, 2004
01civicboi's Avatar
01civicboi is an unknown quantity at this point
Originally posted by Sim012
hydro...
wtf?
Old Jan 18, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
^^ chronic...weed...pot...hydro.
Thread title "want to get high?"
Put 2 and 2 together.
As far as the topic at hand, get components. Go to stores and listen till you find a pair you like. Some sets with loud highs are Focal, MB Quart and Boston Acoustics. Of those three I think MB Quart has the smoothest tweeters, but go listen and see what you like.
Old Jan 18, 2004
WhiteRabbit's Avatar
crossover, or bass blockers. thats the way id go
Old Jan 18, 2004
doubledeuce2k2's Avatar
OT, but did you get to check out the quart demo vehicle alex053? and i'd luv some QSD 164 midbasses
on topic, crossovers and maybe upgraded tweeters would be a big help.
Old Jan 19, 2004
ghostshaddow's Avatar
ghostshaddow is an unknown quantity at this point
definately upgrade the tweeters.... you did the drivers already, now you need a more eficient tweeter to give you as much output as the mids with the available power
MamaBear2015
49
Sep 29, 2015 01:12 PM
JMKendrick
Sep 16, 2015 06:17 PM
JJ291
Sep 2, 2015 11:49 PM
silentz
Jul 9, 2015 08:16 PM
