woofer blown?
Old Nov 18, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
woofer blown?
what are the symptoms of a blow woofer? I have infinity components installed in my front doors running off an 80x4 amp. For about a year now, they have been sounding great. my dad borrowed my car one day and as a joke left the HU turned practically all the way up, past the point of distortion. besides doing a good job of wakin me up in the morning, i think it blew my driver side woofer. At first is wasnt that noticable, but the woofer started cutting out more and more each day. If i turn it up almost to the point of distraction, it will start playing again, or if i put on a song with alot of mid bass. Im going to pull off the door panel on friday to take a look at it. could it just be that the wires worked themselves loose? any other suggestions would be greatly appreciated. thanks.
Old Nov 18, 2003
Connie's Avatar
you wont hear ANYTHING from a blown speaker
(I blew 2 infinity perfect 12.1 and am now onto a 12.1 DVQ )
Old Nov 18, 2003
any suggestion on whats causing the problem?
Old Nov 18, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
well most people would say it is your amplifier. Depending on what it is, it could be too powerfull, or your settings could be wrong on the amplifier.
Old Nov 18, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
I would say loose wires if it's cutting in and out and the amp is staying on.
Old Nov 18, 2003
doubledeuce2k2's Avatar
yeah check for bad connectors. anytime i use the wires speakers come with i end up popping the door off to fix it again. solder those suckers on there.
Old Nov 19, 2003
ive pretty muched ruled the amplifier out since my passenger side set works fine. ill check the connections on friday
Old Nov 19, 2003
fonto's Avatar
The LA Clipper
Re: woofer blown?
Originally posted by grenloch101056
[B] my dad borrowed my car one day and as a joke left the HU turned practically all the way up, past the point of distortion.B]
LOL, dude, how old is your Dad!!?? That is funny as hell that he would do that
Old Nov 19, 2003
hes 46, he has a strange sense of humor
Old Nov 19, 2003
chriscivic's Avatar
chriscivic is an unknown quantity at this point
maybe one channel of the amp is bad. Switch the left and right side and see if the passenger one cuts in and out when it is switched.
Old Nov 19, 2003
LudlamTheory's Avatar
i boogie for the raindrops
question: when it DOES play, does it play perfectly clear?
Old Nov 19, 2003
no, it sounds distorted, i tried switchin the channels and it had the same problem. could the crossover be the culprit?
Old Nov 19, 2003
most likely something is wrong with the woofer itself
Old Nov 20, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
Sounds like it has a seperated voicecoil. Theres no fixing it, if thats the case tho. Its an internal issue.
Old Nov 20, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
Check wiring...
Usually a blown woofer will have a tiny scratching sound.
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
General DIY
Sep 25, 2015 08:02 PM
Mc7602
Sep 17, 2015 02:01 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
