suggestion for amps
Old Nov 16, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
suggestion for amps
what amp u guys think i shud get for a 12" id max v3" i was thinking of getting either the pg tantrum 1200 or the kicker 1200, but both are kinda pricey. it wud be kool to save some money, but i wud rather spend the extra money to get reliable stuff.
or instead of the id max i mite get a pair of jl 12w3v2. i have a pg octane r8.0:1 rated 600 wrms at 2 ohms i think, wud it work well with a pair of jl's? i think theyre svc so if i got them at 4 ohm and wired them in parallel it wud work, but im not sure
Old Nov 16, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
If you already have that amp get the JLs.
The w3's are DVC so you want the 2 ohm ones to end up w/ 2 ohms for the pair. Wire each in series inside the box. Then wire them together in parallel to the amp.
Otherwise I would go w/ the PG amp. I think the Kicker only has a 12db crossover.
Old Nov 17, 2003
LudlamTheory's Avatar
i boogie for the raindrops
id take an idmax over 4 w3's... idmax is an incredible driver. as to amp choice, its all dependant on whether you get the dual 2 ohm or the dual 4 ohm max
Old Nov 17, 2003
dKj's Avatar
dKj
well i wudnt get 4 jls haha just two and use just the scratched up amp and then sell the other pg amp i have which is perfectly fine. it wud save more money than going with the id max and bigger amp.
Old Nov 17, 2003
fonto's Avatar
The LA Clipper
ID Max all the way!!!!!!!!!!!!!!!!!!
Maybe try a dual 4 ohm Max off of that 600 watts RMS PG amp before you invest in another amp.
runawaykinms
15
Mar 22, 2019 10:32 AM
siliconvalley
Sep 15, 2015 09:48 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
