Infinity anyone??????
Old Oct 20, 2003
Placebo3681's Avatar
Placebo3681 is an unknown quantity at this point
Anyone know how good Inifnity speakers fit in the 2k1 civic? I would like to install Kappa Perfect 6.1 and I already ahve 62.5i speakers i got for free. Anyone know for a fact that these speakers fit? Any advice would be greatly apprecaited. Thanks.
Dan
Old Oct 20, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
well, i know they fit. I got my car used, and the guy had Infinity's in the front and rear. They were 63.3i's in the front though. I just took them out because he blew one of the rears (blew stock one, then replaced them and blew that one too), so I didn't know what condition the others were in. Anyway, I'm 90% sure they'll fit.
Old Oct 20, 2003
fonto's Avatar
The LA Clipper
They won't fit in the door without Major modification. I have Perfect 6.1 in Q-logic kickpanels...and they Barely fit with the grill. Infact...I think the magnet hits the carpet a lil in the back.
I promise you that perfects will not fit in the door without having to cut metal on the door, plastic on the door, and using a 1 inch spacer. This is first hand info from someone who has Perfects.
Old Oct 20, 2003
My sedan has a complete 6.1 speaker infinity sound system. The 6.5 speakers are in doors and rear deck, and I've even got separate tweeters up top. So yes, they'll fit. I'm not sure though if you're talking about the 6.5s or something else. The 6.5 speakers will fit. Coupe has 6x9 in the rear, though.
Old Oct 21, 2003
fonto's Avatar
The LA Clipper
LOL, either you are not talking about Perfect 6.1s...or someone did the installation for you and you just don't know the madifications that the installer had to do.
Old Oct 21, 2003
816Buddha's Avatar
816Buddha is an unknown quantity at this point
i got the 6.5 kappa's in the front but had to do a little modification cuz the metal ring was hittin against the speaker. in the back i got the 693i if i remember correctly. it barely fits but it rubs on the crossbars in the trunk. i dunno if that makes any sense at all. i went to the infinity website and it said that those would fit a 01 coupe so maybe you should check it out.
Old Oct 21, 2003
Ahem, I installed almost all my ice and know how the entire car comes apart.
Old Oct 21, 2003
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
if you have a coupe the 6 x 9 will not fit becasue the magnet will rub against the truck bar, unless you take out that bar they will fit. I have infinity reference series powered by a rockford 4 ch 500 X amp sounds really nice. for the sub I have a 10 inch sony xplod powered by a 2 ch 300 watt kenwood amp. sounds pretty clean very little rattle.
Old Oct 21, 2003
fonto's Avatar
The LA Clipper
Dude, check your speakers...they are not Kappa perfects...they are probably Kappa series, which should fit pretty easily. Kappa Perfect 6.1s will not fit in the door without Major modification. Besides, Perfect 6.1s would probably sound pretty crappy in the doors. If you read the instructions for the speakers they are optimized for kick panel installation.
Old Oct 21, 2003
Okay, forgot to mention mine are reference series that fit fine.
Old Oct 21, 2003
fonto's Avatar
The LA Clipper
LOL, ok...he was asking how Perfects would fit...If you give false info he might beleive it.
Old Oct 22, 2003
cdmx's Avatar
Has anyone ever heard a basslink?
Old Oct 22, 2003
doubledeuce2k2's Avatar
in a store yes. what'd you wanna know about it though?
Old Apr 19, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
http://www.infinitysystems.com/carau...t.aspx?ProdId='KAPPA692.5I'&Ser=KAP&Cat=MEL
i'm looking to install infinity kappa 692.5i 6x9's into my car and infinity says mounting depth is 3-3/16"
shouldnt that fit in the 7th gen coupe w/out hitting the trunk springs?
i currently have MTX 3way 6x9's in the car and specs say mounting depth is 3-1/4" which is more than what the infinities require
what's is the kappa's magnet diameter? maybe the magnet diamerter is larger than my MTX speakers so that's why the kappas wont fit?
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Jeffdp
Aug 5, 2015 11:38 AM
swkfilms
Jul 8, 2002 11:32 AM
dups
Jun 11, 2002 02:08 AM
ZSKCivic01
Apr 22, 2002 11:54 PM
