Speaker Size???
Old Oct 6, 2003
tgalli12's Avatar
tgalli12 is an unknown quantity at this point
Question Speaker Size???
Does anyone know what the max front speaker depth is?
Old Oct 6, 2003
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
2.25" is about the maximum depth of the speaker...
The window MAY/May not go down completely after the installation of the speaker... but it should.
If your speaker is deeper than that.. get a spacer... the max spacer you can use is a 1" spacer.. the bottom of your door panel will pop out just a touch... after using a spacer.. however, you can cut the inside of the door out... so the door is seated properly again.. but that choice is entirely yours.
Old Oct 6, 2003
tgalli12's Avatar
I'm lookin to get focal polyglass speakers. The depth on them is exactly 3.62 inches. Do you think I will be able to sqeeze it in there and still have the window go down? Do you think i could use a bigger spacer and make it fit?.
UltraHDGames
Jun 8, 2016 05:16 PM
68camerors
Sep 24, 2015 06:18 PM
Gsxtacy
Sep 12, 2015 01:09 AM
