Help With My Amp
Old Sep 10, 2003
nguyen949's Avatar
nguyen949 is an unknown quantity at this point
Help With My Amp
i have a avionixx 1200.2 amp...i just installed it and it has that red light on which says "protected" and the power light does not come on...help plz...
Old Sep 10, 2003
Mr.Modify's Avatar
is it overheated? Has it worked meaning have you been "beating " for a long time with it? if so just give it a couple minutes and it should be fine...at least that's what happens to mine!!
Old Sep 10, 2003
Bogus1's Avatar
Bogus1 is an unknown quantity at this point
make sure all your cables are securly fastened. I had my ground cable alittle loose and some thing similar was happening to me.
Old Sep 10, 2003
nguyen949's Avatar
all my cables are fine nd everything i dunno why its not workin...=/
Old Sep 10, 2003
civic01vtec's Avatar
maybe u blew the fuses on the amp...........try changing them.
Old Sep 10, 2003
Bogus1's Avatar
Did you have it workin' before?
Old Sep 10, 2003
fonto's Avatar
The LA Clipper
What ohm speakers do you have connected to it? ...and how many?
I would also triple check your ground.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
