HELP!!! RCA/AMP/SUBWOOFER problem
Old Sep 2, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
I am having a problem with my subwoofer. I recently sent off my amplifier to circuit city to have it serviced. When the amp was returned they just replaced the rca outputs on the amp.
Well the problem i am having is that sometimes my sub will hit fine then sometimes it doesnt hit as hard for a short time. But, when i kinda hit right below my headunit the sub hit like normal. I am starting to think that i possibly have bad rca's.
what do you all think about this situation and what is going on?
Injen
Old Sep 2, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
OK, so you sent your AMP out, and they replaced RCA outputs or inputs? What was the problem you sent the amp out for?
And when you hit the dashboard below the headunit, the sub fixes itself?
I would say take your HU out and make sure the RCA's are in tight. Obviously its going to be either a wiring or HU problem since when you hit it, it starts working again.
Old Sep 2, 2003
injencivic's Avatar
the amp was sent out for loss of power. and they replaced the rca inputs.
I am gonna take it apart tonight at the house to see if the rcas are fine or not.
Injen
Old Sep 2, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
If it accepts a signal its an input (HU to amp).
If it ouputs a signal its an output (this amp to another amp).
Old Sep 2, 2003
injencivic's Avatar
thanks, then its input
Injen
Old Sep 3, 2003
injencivic's Avatar
bump for Ludlam Theory
Injen
Old Sep 3, 2003
LudlamTheory's Avatar
i boogie for the raindrops
have you possibly checked that maybe theyre half unplugged behind your headunit? or that only one of the two is plugged in back there?
Old Sep 3, 2003
injencivic's Avatar
i am gonna check today when i get off work. I am guessing thats what it is more then anything. At least hoping.
Injen
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
