2-channel or 4-channel???
Old Aug 13, 2003
CIVICONBAGS's Avatar
CIVICONBAGS is an unknown quantity at this point
i decided to only power my components in front ... i want to power the woofer and tweets only 100 watts... so would it better to have a 200w/ch. 2 channel amp connected in series work the same as powering the speakers by a 4 ch. amp individually? can you do this?? how would the inputs on the rca be if you can??
Old Aug 13, 2003
by the way are jbl amps rated by rms or peak power ???
Old Aug 13, 2003
LudlamTheory's Avatar
i boogie for the raindrops
what components?
Old Aug 13, 2003
i have fausgate fanatic p sets but plan on going either focal polykevlar or diamond hex or m6
Old Aug 13, 2003
basically all im asking is can i use a 4 channel amp and be able to bridge the connections ??? cuz im planning on just buying a jbl 360.4 amp to power all 4 speakers but later want to upgrade to better speakers and instead of going wit a better amp i want to be able to bridge the connections to raise the wattage
Old Aug 14, 2003
nevermind stupid question... i jus realized i could do it ... =P
Old Apr 16, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
What I wonder is that I noticed some people on here actually power the tweeter separately from the woofer of a component setup.
My Kicker Resolution tweeter says it has a 150watt rms while the woofer is 100watts rms. I was planning on bridging the 4 channels of a 5ch amp to get 150watts for 2 channels. Will the 150 watts be divided in half between the woofer and tweeter?
Old Apr 16, 2004
Ed's Avatar
Ed
yeah, it'll be divided, as per the crossover. you could bi-amp it you were so inclined
