DIY: My custom audio setup!
Old Aug 3, 2003
Hey all,
I've made some major ICE changes and rearranged my whole setup. I used to have two 10 subs and recently installed a four channel amp for the speakers. I'm also running tweeters off the deck. Well, I decided to save weight by going to only one sub. The amps were mounted on the box, but now they're on the trunk floor around the sub. Check out my ride page for a pic of the setup.
Here's a summary of what I did if any of you like the setup. It's pretty easy.
1) Remove stock carpet piece so you see the thin cardboard above the spare.
2) Get a wood board (1/4 inch thick) and cut it so it fits from right to left and extends out just enough for the sub box to sit on.
3) Use a circular saw to cut out holes for each amp on either side. You want the sub to be on the top of the wood. The amps should be sitting in the holes you just cut and can later be screwed in to the hard cardboard cover (stock).
4) Cut some new carpet using the old piece as a template. This way you won't have to cut up the stock carpet. After cutting the new carpet, make holes for the amps (but leave some extra to fold over the cuts). Take the wood piece you just made and glue the carpet to it. I used heat resistant spray adhesive and folded the carpet around the amp cutouts.
5) Put the wood piece and carpet back in the trunk and mount the amps. The sub goes in the middle. To make the rest of the trunk space level with the wood peice in the front, I cut 1/4 inch carpet foam to the proper shape and glued the remaining carpet to that. This will make the carpet even throughout the trunk.
6) The hard part is done. For the actual covers on each amp, I used heavy cardboard. There is only one piece going over each amp, and one smaller piece in front to give the illusion of a box. The sides and back are open for air circulation. I used the same spray glue and some tape to attach the two cardboard pieces together and put carpet over them. The covers are just sitting on top and can be removed.
I know it's hard to see how to do all this without pics, but I may be able to explain it better if you have questions.
Let me know what you think
Old Aug 3, 2003
DaZeD's Avatar
Don't Hate. Just Envy.
put some pics up, it sounds pimp
Old Aug 17, 2003
Here's a pic
Old Aug 17, 2003
civicvtec1ps's Avatar
Search and Learn
looks tight. very clean setup. i need to make box myself.
my q logic box is taking too much space
Old Aug 17, 2003
pheaton's Avatar
A descendant of 2k1civic.com
hehe . . too much space. . you mean like this?
Old Aug 17, 2003
Sim012's Avatar
Sim012 is an unknown quantity at this point
Hurr's Mine
Here's mine. Im thinkin of actually sellin these. SO if anyone is interested make offers and holla at me. PM or Sim012@hotmail.com
Old Aug 17, 2003
Sim012, great setup. Circuit city installed my subs and amp and didn't adjust the levels properly. I'm now getting the same sound from one sub that I used to get from both. It's also amazing what a small 4ch amp and tweeters can do for your system!
Old Aug 17, 2003
Search and Learn
heres mine.
i do want to make custom box though. thing is .. i would like to use my spare tire as well. some people had thier spare tire under the car but i dont want to do that.. i suppose i could make smaller box than q logic one i have. this one is VERY heavy
Old Aug 17, 2003
pheaton's Avatar
Mine is sooo heavy. . It's all 3/4" MDF .. Sounds really really nice though ..
Old Aug 17, 2003
My dual box was heavy, too. That's one reason I decided to go single. There isn't much room to work with if you decide to keep the spare. With my setup, though, it would take an hour just to get under there.
Old Aug 17, 2003
LudlamTheory's Avatar
i boogie for the raindrops
moooooved to correct forum here now...
Old Aug 18, 2003
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
here's mine:
neon light goes on when car's on. was too lazy to turn it on lease:
Old Aug 18, 2003
gliph's Avatar
gliph is an unknown quantity at this point
Here's mine, just finished this weekend... you can't see the sub since it faces forward, so i'll post that too.
Old Aug 18, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
OMG your setup is so similar to mine. I like it.
Old Aug 18, 2003
Search and Learn
gliph
looks nice and clean.
good setup
Old Aug 19, 2003
AzNBonD's Avatar
AzNBonD is an unknown quantity at this point
I had this done quite a while ago. It's on a 1.7EL. These are older pics, I've done a bit more to it, but you get the idea.
Here was one of the final phases:
Old Aug 19, 2003
iLLuMiNaTi's Avatar
very nice aznbond! did u make it yourself? how much did it cost??
Old Aug 20, 2003
alex053's Avatar
just to make it easy on me...anybody know what the angle of our back seats are...so that i can have the back of the box flush against the seat??
Old Aug 20, 2003
AzNBonD, you have a sweet setup! Don't know the exact seat angle. Just look for a box with the rear tilted a bit.
Old Sep 15, 2003
AzNBonD's Avatar
god i need to login more often
materials were about $60-80. i had a lotta stuff from before and such, especially since we recently developed our basement. i had a bit of 1/2" plexiglass left. as well as lumber. i just bought an MDF sheet (3/4), white LEDs, cotton batting, terminals for subs and leds, vinyl.
i just took out my enclosure today because my car got hit and they needed the trunk emptied out since its going in the bodyshop tomorrow. I'll be taking detailed measurements since someone requested it. as well, i'll post my cache of pictures i used when i built the enclosure.
i'll be reapplying some vinyl, refinishing the amp enclosure. in addition, i'll take the opportunity to completely sound proof my car and insulate some larger areas (I live in edmonton, canada guys. it gets cold here!!). as well, i'll be making a fibreglass trunk lid undersite, as well as a fibreglass cover for the underside of the rear deck (as well as having a little box for the rear speakers). the side carpetting needs to be dyed as well.
Old Sep 15, 2003
Tre's Avatar
Tre
Tre is an unknown quantity at this point
Here are a couple pics of my ride...
I never finished the project 100%, and am planning a new setup as we speak. I need to sew a vinyl cover for the spare tire. My future plans include mounting the three amps recessed into the back of the rear seats. BTW: I used the spare tire well to house a 1.1 cu ft. mdf box for the 12" Pioneer sub. The floor was only elevated about 3.5".
Old Sep 16, 2003
GreenNVicious's Avatar
Newbie
I wanted to def make a new floor for it, since the stock "floor" is hella cheap and weak. But I might do black vinyl all around, def doing a new mount board (to hide all the wiring) and find a place to put my damn spare.
Old Sep 19, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
lol u guys got some nice setups. i will post mines once my car gets fixed.. (someone hit it wen it was parked)..
COMPUTER FANS!!!.. they fuqqing rock!! haha i have 3!! to help air circulate
Old Sep 20, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
here's mine. there room for 1 set of golf clubs in the trunk
Old Sep 20, 2003
Cool setup, and you have Infinity subs I see. Good job.
Old Sep 21, 2003
AzNBonD's Avatar
HUGE MISTAKE porting into the trunk
i made the same mistake and jab myself with a pen everytime i think of it. *oww*
now that my system is out, i'll be rebuilding a new box porting into the cabin. there just isn't enough airspace inside the trunk.
Old Sep 22, 2003
OyD's Avatar
OyD
i had the box ported to the front with the last box i had. this one sounds quite a bit better
Old Sep 22, 2003
AzNBonD's Avatar
the trunk doesn't have enough airsprace
Old Sep 23, 2003
sham01ski's Avatar
sham01ski is an unknown quantity at this point
hot setup... must sound pimpin
Old Nov 10, 2003
pitciv's Avatar
pitciv is an unknown quantity at this point
holy crap!! i love how the carpet covers alllllll the metal in the trunk!! How did u measure that out? please tell me im really interested
