help choosing a amp
Old Jul 28, 2003
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
help choosing a amp
i have two 12" kicker solo-baric l5's the specs are 600rms and 1200 peak. my question is what amp would you recommend i have been searching around and have not found anything at a decent price that will run the two subs im looking for something like 600 x2 rms and 1200 peak (duh)
Old Jul 28, 2003
LudlamTheory's Avatar
i boogie for the raindrops
are they dual 2 ohm or dual 4 ohm... how much are you looking to spend amp-wise
Old Jul 28, 2003
sadboy916's Avatar
4ohm oops should have said that. price is also important but i tend to find lower prices than anyone else for example i paid 150 for the kicker (each)
Old Jul 28, 2003
so you want 1200ish watts at 1 ohm...
whats your price range
Old Jul 28, 2003
sadboy916's Avatar
LudlamTheory whats your aim i would like to talk to you on it so i can get more info faster my aim is kingsfns
Old Jul 29, 2003
dKj's Avatar
dKj
dKj is an unknown quantity at this point
i thnk theres that one phoenix gold, tantrum i think? 1200.1 i dunno the impedence. ive been through 3 phoenix gold amps, and i like them. and the octane r's look sick, but kinda expensive.
Old Jul 29, 2003
pg tantrum is 1200 @ 2 ohms, he needs one at 1 ohm
look into the hifonics brutus amps.
they have a 1000 @ 1 ohm and a 1500 @ 1 ohm that are both REALLY nicely priced
Old Jul 29, 2003
AntDeezy's Avatar
I am in love with all JL amps right now, the JL stuff jus tends to be more expensive.... but to me is worth it ...
Old Jul 29, 2003
targetpractice's Avatar
targetpractice is an unknown quantity at this point
The only problem is the JL amps are the same power rating no matter how much you drop the Ohms. Look for like a Orion HCCA 2100 off ebay or something, Stable at 1 ohm mono or .5 ohm in stereo and I think they are rated at 1200x1 rms in 1ohm. which split between two subs would be your 600 rms. I stand behind the orion product because I have an HCCA 250 running my 4 10" Kenwood Excelon DB's with no problems
Old Jul 31, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
I'd do a JL 1000/1 if I were you and run the subs at 4 ohms total, 4 ohms means you'll have a higher damping factor, means the amp will have more control over the subs means tighter bass.
Old Aug 4, 2003
civic01vtec's Avatar
It depends on what type of enclosure u will be putting the subs into. My friend has (2) 12" L5's in a ported box (slotted port) with a 600W kicker amp and he is banging high 140's. If you are going ported, then u can get a smaller amp, if u are going sealed, then u will definitely need more power. Or u can bulid 2 seperate boxes or one box with a divider and put a 2ohm stable amp on each sub. This could be the cheaper route if u get the right amps. Personally, i only use xtant amps. They are always underated from the factory. I have the 1001 and it is rated for 1000 watts down to .5 ohms and it was bench tested at almost 1300. I ran (1) 15inch RFL off it in a slot ported box with one battery and i consitently hit 150 db's. My highest is 150.8 db.s with no dynamat. Remember, there is no govt. regulation on ratings and some compaines rate their amps for 1000 watts and they may only be pushing 800 watts. The bottom line is, u get what u pay for.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
General DIY
Sep 25, 2015 08:02 PM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
