Speakers won't work
Old Jul 26, 2003
Xerxes3333's Avatar
Xerxes3333 is an unknown quantity at this point
Unhappy Speakers won't work
Hey guys..
I have a 99 Honda Civic EX. My CD reciever has been a hasle. I finally got it working.. then driving down the road one day.. it decided to stop sending music to the speakers (for lack of better words). One of the red wires was touching the metal I guess and it kept going on and off.. Eventually.. the fuse blew. After I replaced the fuse, the speakers still wont work. I have checked every fuse in my car.. they are all fine.. I have checked the connection.. also fine. Do you have any idea what my problem is? I would really appreciate any help. Thank you so much.
Regards,
Patrick Johnson
Old Jul 26, 2003
Xerxes3333's Avatar
anyone?...
Old Jul 26, 2003
doubledeuce2k2's Avatar
i think the red wire is usually the remote turn on lead. this is the wire that tells the radio when to turn on (when the key is in on or ACC position). u said you checked, but check #8 on the interior fuse box ( 3rd in from the right on the bottom row, should be a 7.5A fuse).
if not buy a cheap multimeter and go to town finding out which wire isn't hot when the car is on, and there's the fix
Old Jul 26, 2003
Xerxes3333's Avatar
well.. that's the thing. The Radio itself works fine. The fuses are fine and the connection are fine. I am absolutly sure of it. For some reason though, the speakers are not playing the music. Is it possible that something happened to the cd player that makes it to where it won't give music to the speakers? I appreciate your help.
Old Jul 27, 2003
tom1178's Avatar
tom1178 is an unknown quantity at this point
red wire is usually switched on, like it provides power when the car is turned on, yellow is usually constant 12 volts power, hooked directly up to the cars battery and always provided 12v power, blue is the remote turn on.
Old Jul 27, 2003
if the amplifier circuit is blown, then it won't work... fuses are designed to protect against too much current going through the machine, but they don't protect against every bad thing that can happen.
i've killed an amp by reversing the 12V and ground connections it blew the fuses but killed the amp anyways.
Old Jul 27, 2003
Xerxes3333's Avatar
well, I don't have and amp.. The cd reciever itself has a built in amp, but that is it. I replaced all the fuses in my car.. and reconnected all the wires.. still no sound..
Old Jul 27, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
There is probably something wrong with the HU. Take it in to an audio shop and have them send it out for repair, or buy a new one. If it's still under warranty (if you bought it from a shop) then it should get repaired for free.
Old Jul 28, 2003
Xerxes3333's Avatar
unfortunatly, I got it from about 7 states away from where I am. How much do you think it would cost to get it fixed at a local place?
Old Jul 28, 2003
Mystic3030's Avatar
They'll usually send it out to another company like "United Radio" to fix....I donno, the shop I go to always fudges a receipt for me that says my warranty is still active, so i've never paid to have anything repaired. I think I remember them saying it's like $80 or something though. Just give your local shop a call and find out!
Old Jul 28, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Before you go sending it off, you might want to check your connections to the speaker leads. If you had a power wire touching metal, you may very well have a speaker lead shorting out too, either against metal or against another lead; if the radio sees that any of the speakers are shorting out, most internal amps will shut themselves off. Could also be a blown speaker. check all your connections first, before you send it off for service that it may not need.
Old Jul 30, 2003
Xerxes3333's Avatar
Well, I installed the old head unit.. and it works fine. . . So the new head unit must be shot.. Is there any way to fix this myself? Like I said.. it still powers on.
Old Jul 31, 2003
Mystic3030's Avatar
Try putting it back in and see what happens....if it still doesnt work, you will most likely have to send it out. And it's probably NOT something you can fix yourself.
Old Jul 31, 2003
Xerxes3333's Avatar
well, luckily.. I believe I have a 1 year exchange waranty, so.. I think I can just replace it.
Old Jul 31, 2003
THERING's Avatar
THERING is an unknown quantity at this point
Best bet exchange you probly fried the speaker channels.
mattdoc
Mar 14, 2017 12:10 PM
ORskier
May 3, 2015 12:54 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Richkid23
Apr 19, 2015 12:53 PM
supercivic01
South
Nov 30, 2001 11:27 AM
